Old 05-09-2016, 08:52 PM   #1
_sams86_
Grasshopper
_sams86_'s Avatar
Drives: Ultramarine
Will 18x9.5 wheels fit on the stock studs?
I ordered a set of Vordoven Forme 9 and am wondering if i will be needing extended studs or would the stock ones hold up? thanks in advance
_sams86_ is offline   Reply With Quote
Old 05-09-2016, 09:42 PM   #2
tyler_win_photo
tyler_win_photo's Avatar
Stock studs will be fine.
tyler_win_photo is offline   Reply With Quote
Old 05-09-2016, 10:52 PM   #3
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
Will fit on stock studs, but what's your offset? You may rub stock spring perch.
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 05-09-2016, 11:05 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
As a general rule (assuming the wheel maker isn't stupid and made some wheels w/ absurdly thick backpad/lug seat):
you'll only need extended studs if you are using slip-on spacers larger than 3mm. Or if you're running racing-type open-ended lug nuts.
-alex
Old 05-10-2016, 01:03 PM   #5
c4lvinnn
Drives: Toyobaruion
this.
Even if this backpad was thick (some are for low offset wheels if not made up by increasing lip/concave), they would shave and drill the lug holes themselves to around 18mm thickness so you wouldnt need to run longer studs.
c4lvinnn is offline   Reply With Quote
Old 05-10-2016, 01:26 PM   #6
mav1178
mav1178's Avatar
We are making assumptions based on the fact that the factory knows what they are doing... but some of them don't.
Some wheel brands w/ cheap/poor quality factories have shipped wheels without properly drilled lug seats.
I know, I've seen it come in from Asia on containers and had to scrap entire pallets of wheels because they weren't drilled properly.
-alex
Old 05-10-2016, 02:04 PM   #7
_sams86_
Grasshopper
_sams86_'s Avatar
Drives: Ultramarine
They are a +34 offset, im on Fortune Autos
Old 05-10-2016, 02:09 PM   #8
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
The sky is blue and my coffee was cold this morning, will my wheels fit?
sdemo is offline   Reply With Quote
Old 05-10-2016, 02:31 PM   #9
c4lvinnn
Drives: Toyobaruion
-alex
I don't associate with poor quality wheels so I don't run into this on a personal basis lol
Forgestar F14 wheels and Enkei wheels: <<RPF1 18x9.5/NT03+M 18x9.5 In Stock>> b2autodesigns Wheels and Tires 850 09-10-2017 09:29 AM
M14 wheels on M12 studs Dihudaxia Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 07-17-2017 10:30 PM
l Ashera Motorsports l Gramlights Wheels - 57DR 18x9.5 +38 in Stock! HUGE SALE!! Info@Ashera Wheels and Tires 27 12-21-2016 03:52 PM
Enkei Raijin Wheels: IN STOCK - 18x8.5 & 18x9.5 Concave Touge Factory Wheels and Tires 27 04-03-2015 06:33 PM
VarrsToen ES6 18x9.5 +35 5x100 Wheels - NOW IN STOCK! Sonic Motor Wheels and Tires 11 04-17-2014 10:14 PM
