Old 05-09-2016, 05:22 AM   #1
EdiVip
Drives: Mario
Right heads explode after high FI - Need help!!!
Hello everyone! I have big problem with my new engine setup and I need advice/solution...
First what i've done in my car:
Stage 1
- AVO Turbo kit Stage 1:
- AVO BOV:
- Death Werks - 700cc
- Walbro - 485
- Perrin - Oil Cooler Kit
~300HP/300NM
Stage 2
- AVO - 8psi Acurator:
- AVO - 3 BAR Map sensor - not mounted!
- Ecumaster - Digital ECU Tuner 3
~330HP/345NM
Stage 3
- AVO - 3" Stainless Steel - Full Exhaust System - Cat manually deleted
- AVO - Turbo upgrade to Stage 3 Billet
- FERREA - Valve springs, Reteiners, Seat relocation
- HKS - 2.1 Stroker kit:
- HKS - Metal Head gasket 1mm x2
- Xtreme - Dual Plate Clutch
After put my engine on my car I went to the dyno for tune. I was looking for over 400HP! But on 6900RPM (380NM and 1 BAR FI pressure) right heads explode! The valve tappet and Rocker arm pivot make hole in head cover and went outside! I changed valve springs to stiffer ones. It isn't enough? Knocking sensor did't recognize anything. It is possible that the reason is UEL AVO headers? What I'm doing wrong?
EdiVip is offline   Reply With Quote
Old 05-09-2016, 06:28 AM   #2
Tokay444
There are far too many unknown variables to even begin to speculate, but I can all but guarantee you it wasn't that unequal length header.
One question, did the 3 bar map sensor ever make it into that motor?
Old 05-09-2016, 06:33 AM   #3
EdiVip
Drives: Mario
No! I bought it but never installed
Old 05-09-2016, 07:11 AM   #4
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Sorry for you luck. What rods and pistons was used?
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 05-09-2016, 07:46 AM   #5
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
I'd say broken valve follower, the FA20 has a history of this
Matt@Cosworth is offline   Reply With Quote
The Following User Says Thank You to Matt@Cosworth For This Useful Post:
Freeman (05-09-2016)
Old 05-09-2016, 08:13 AM   #6
FRS Justin
Drives: 2013 Asphalt FRS
What year is the motor did you order the right valves for the year of the motor? Rocker arm pivot break? Need to know more along with pics if you have any
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 05-09-2016, 09:40 AM   #7
EdiVip
Drives: Mario
HKS Stroker Kit 2.1l with 2x1mm gaskets on each side
Valves are OEM. Rocker arm pivot break and went outside also. Similar situation to this but on ~7k NOT 9k rpm!?
http://www.ft86club.com/forums/showthread.php?t=73858
I'll post pics asap!
Old 05-09-2016, 09:48 AM   #8
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
This is rocker arm failure. The valve rocker arms are not secured from the factory. You can pull 'em right off. If a valve ever sticks, the rocker arm is flying out the valve cover like you described. Happened to me, too, as well as a lot of others.
Element tuning has a small write-up regarding this failure on their site here:
http://elementtuning.com/competition...r-wrx-fa20dit/
Look for the Are there any weaknesses we address? section. The fix: find a way to secure them.
BTW, get that 3bar MAP sensor on. Assuming you're running the stock MAP sensor currently by your post, the stock MAP does not handle positive pressure well. Get that new MAP sensor on before you tune further.
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZoomTX For This Useful Post:
dp1 (07-08-2016), FRS Justin (05-09-2016)
Old 05-09-2016, 11:48 AM   #9
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Oh, video of the rockers for reference.
https://www.instagram.com/p/BEaO3riR...en-by=brzoomtx
Old 05-09-2016, 12:34 PM   #10
GsxrMe
GsxrMe's Avatar
Does anyone offer a direct replacement to the factory rocker arms other than inspection?
2014 Subaru BRZ
Old 05-09-2016, 01:14 PM   #11
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Why would you be running such a high PSI tune without a map sensor installed that can actually read pressure that high?
Old 05-09-2016, 01:22 PM   #12
EdiVip
Drives: Mario
I think this is it! Below missing part!
My tuner told me that is not necessary because they can read FI pressure from different place. I don't know exactly from where but If U want I can ask him!
Old 05-09-2016, 01:35 PM   #13
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Yep, just like mine. No pin failure but the rocker itself shot out as one entire piece. You're looking at possible camshaft damage as well. On mine, both right side cams received damage on the actual contact point for the rockers, so I've been advised to replace both.
Old 05-10-2016, 03:35 AM   #14
SPCorBUST
SPCorBUST's Avatar
whats the fix so that these types of failures don't occur?
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
The Following User Says Thank You to SPCorBUST For This Useful Post:
Chad86 (05-20-2016)
CA-FI Heads Up Display XtremeMaC Electronics | Audio | NAV | Infotainment 3 08-18-2015 08:41 AM
Heads Up BRZ Available In So Cal ZmZMWagon Southern California 17 06-18-2012 03:10 PM
