Old 05-04-2016, 10:22 PM   #1
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I Built a Tire Trailer!
I'm going to be a super-huge jerk, though, and force you to click through to my blog to read it because I already spent too much time formatting everything there to reformat everything here, lol.
http://www.seriesblueadventures.com/...a-tire-trailer
Stang70Fastback is offline   Reply With Quote
Old 05-04-2016, 10:29 PM   #2
Speck
Drives: '13 FR-S
Dude! So cool. Nice work!
Speck is offline   Reply With Quote
Old 05-05-2016, 08:56 AM   #3
CarzCarzCarz
CarzCarzCarz's Avatar
Drives: 2014 WRB BRZ
Nice work and write up. Thanks for sharing
CarzCarzCarz is offline   Reply With Quote
Old 05-05-2016, 09:43 AM   #4
extrashaky
Drives: 2014 BRZ Limited
You're a braver man than I. I don't think I would trust a bolt-together Harbor Freight trailer with a wobbling wheel behind my car.
Old 05-05-2016, 10:14 AM   #5
Stang70Fastback
A.K.A. Starlord
Yeah, I suppose it sounds a lot worse than it is. However in reality, this trailer could probably be pulled over one of those test courses they use to destroy cars all day long and be just fine. It might be a basic bolt together trailer but you use quite a few bolts, and once it's properly put together, with a thick floor attacked, it doesn't feel any less flimsy than if it were a thick, welded trailer. It's a good example of "too simple to break."
As far as the wobbly wheel, that also probably sounds worse than it is. Nothing is loose, it's just a steel wheel that's slightly bent. No real threat to anything in the short term, but I do need to get it fixed eventually, lol.
Old 05-05-2016, 10:25 AM   #6
yberther
yberther's Avatar
Drives: '13 SWP Limited
Make sure you repack the bearings with good bearing grease. If there is any grease in there to begin with, the quality is shit. Bearing buddies or just replacing them will ensure it will ride better longer. I've had mine setup for a motorcycle (not towing with my brz) for a couple years now and changing the grease and adding the 3/4" ply made it much more tolerable. The plywood really stiffens it up and for $200 it can't be beat.
yberther is offline   Reply With Quote
Old 05-05-2016, 10:36 AM   #7
Sideways
BRZZZZZ
Sideways's Avatar
Drives: 2013 BRZ Whiteout
Great work thr. Even I was thinking of grabbing that trailer for my car.
Sideways is offline   Reply With Quote
Old 05-05-2016, 10:38 AM   #8
extrashaky
Until it doesn't. Maybe it'll be fine. But I've bought a lot of stuff over the years from HF, and while they're great for some things, the quality of their materials doesn't always inspire confidence. I would be worried you couldn't torque the Chinese screws tight enough without stripping them, and that without proper torque on them they would back out under constant vibration from your wobbling wheel.
Is that thing even meant for road use? It looks like it's intended for towing stuff behind a four-wheeler around the farm. I think I would head around the corner to Northern Tool instead if I wanted an inexpensive trailer that was roadworthy.
Old 05-05-2016, 10:46 AM   #9
Stang70Fastback
A.K.A. Starlord
Yeah, you aren't the first person who has suggested that to me. For the time it's running on the grease it came with. I've never "packed" a bearing before, so I'm hoping sometime this summer I can buy some "nice" bearings and grease and get a friend to help show me the proper method for doing it. As it stands, I pretty much just shoved the bearings it came with in and called it a day, lol.
If you Google "tire trailer" you'll find that this is the trailer kit used for a significant percentage of them. As far as the quality goes, the beauty of this trailer is that there isn't much that can be "poor quality." You've got the six main frame pieces, all of which were well painted, and all of which had the holes stamped in the proper spots. You've got leaf springs, an axle, some wheels, and some hardware. All of the nuts I installed were lock nuts, and they were tightened about as tight as I could turn them with my socket set. They will definitely NOT be coming loose. At least not for a very long while.
The trailer is rated for road use, which is why it came with all of the legally required lighting. It is fully DOT compliant. I believe the tires are rated to 55 MPH but apparently people tow them at much higher speeds all day long without issue. In the long run I'd like to replace the wheels and tires with proper radial tires instead of the cheap bias-ply ones it came with.
Old 05-05-2016, 11:14 AM   #10
yberther
yberther's Avatar
Honestly man, if you built all this, its super easy to buy some good grease and just pull the old stuff out, fill it with good grease, then you don't have to worry.
[ame="https://www.youtube.com/watch?v=tNOeMCeWWn4"]How to Grease / Pack Trailer Wheel Bearings : Trailer-In-A-Bag Example - YouTube[/ame]
Old 05-05-2016, 11:16 AM   #11
extrashaky
Well, if you're comfortable with it... I'm still wary.
BTW, great job on the customization. It looks good, and your mods are very functional. I didn't want that to get lost in the concern over the quality of the trailer itself.
Old 05-05-2016, 11:22 AM   #12
Stang70Fastback
A.K.A. Starlord
Oh. I hadn't actually looked up a how-to yet. I thought "packing the bearing" was going to be some complicated process. I didn't realize it just means shoving a shit-ton of decent grease in there. Should I replace the bearings with some "higher quality" units, or are the ones from HF sufficient? I want to be able to tow this trailer at 70-80 MPH without worrying about the bearings overheating.
No problem, and thanks! I can understand your concerns. I'm wary of all HF products to be honest. In fact, even though everyone says their jacks are fine, I still spent considerably more money on a different brand jack to ensure it would be a good one. This trailer is something much simpler, though, so I wasn't quite as concerned. My degree is in aerospace engineering, so I promise you if it truly was flimsy, or really felt like it wasn't up to snuff, I would be the first person to point it out, lol :P
Old 05-05-2016, 11:38 AM   #13
yberther
yberther's Avatar
Yea, I'd put quite a bit more than he did in the video. If you use your palm you can literally fill the cavity completely. That is the correct way to do it.
I've had no problems with the stock bearings and I wouldn't be worried with how little load is on your trailer. Awesome work otherwise. Little cars with tire trailers looks so awesome.
Old 05-05-2016, 11:43 AM   #14
Stang70Fastback
A.K.A. Starlord
Oh, so literally put the wheel on, and then pretty much pack the entire void FULL of grease, smother the bearing in grease, shove it into the grease, fill the CAP with grease, and basically just make it so that when you put everything back together it's all grease and no air? That seems pretty simple, lol.
anyone selling tire trailer for track/autox? didinyc NY / NJ / CT / PA 2 03-30-2015 12:19 PM
Car Trailer GotBRZ1691 Northern California 3 02-11-2015 04:10 PM
New F&F 7 Trailer sdwagonjp Off-Topic Lounge [WARNING: NO POLITICS] 11 11-02-2014 01:40 AM
Dai Yoshihara's 2014 Falken Tire/Discount Tire Subaru BRZ FD Reveal SnapOv3st3r BRZ Photos, Videos, Wallpapers, Gallery Forum 62 04-15-2014 02:26 PM
Damage to built up area of sidewall/stock tire. Zadkiel Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 09-25-2012 09:03 PM
