Drives: Toyota
CarJoying Head Unit
I have a 2014 Scion FRS and I'm planning to get a carjoying head unit.
It's not the Toyota Model but the Universal model.. I'm wondering if this is how you wire it and if it is compatible? This is the head unit https://www.carjoying.com/android-5-...rt-revers.html Because it is a universal model.. I need the harness.. This is the harness https://www.carjoying.com/joying-har...ess-cable.html __ Because it is a double din and not toyota universal unit.. I would need the double din dash kit.. http://www.carid.com/american-intern...pn-ttr992.html __ What other modification would I need? And would the installation process go like this? Remove Headunit -> Repin toyota harness from Pin 9 to pin 8 -> Connect toyota harness to the car harness -> Plug into new headunit -> Screw everything back in Or can I just get this harness?? [ame="http://www.amazon.com/Wiring-Harness-Adapter-Toyota-Adaptor/dp/B00ZIBBK78"]Amazon.com: Wiring Lead Harness Adapter for Toyota ISO Stereo Plug Adaptor: Automotive[/ame] Last edited by FRSure; 04-27-2016 at 01:42 PM. |
Drives: 2013 86 GT Black
Hi FrSure,
How did you go? Did you install the HU into you're car? |
Im keen to know if you install that particular HU in your car? Was it easy enough?
| OEM BRZ Head unit | shdobxr | Audio/Visual, Electronics, Infotainment, NAV | 10 | 11-06-2015 12:43 PM |
| new head unit | mrnibbs | Electronics | Audio | NAV | Infotainment | 3 | 06-04-2015 07:58 PM |
| BRZ Head Unit Into STI | iamdaspoon | Electronics | Audio | NAV | Infotainment | 2 | 05-23-2015 03:06 PM |
| FS: BRZ OEM Nav Head Unit | Griever423 | Audio/Visual, Electronics, Infotainment, NAV | 2 | 09-23-2014 03:02 PM |
| head unit in GTA | excited86 | Electronics | Audio | NAV | Infotainment | 1 | 06-18-2012 07:42 PM |
