Old 04-27-2016, 02:35 AM   #1
Lord09
Drives: 2015 BRZ
2014+ Entune FR-S Radio Swap to BRZ
I tried searching, but I didn't find any concrete info about a FR-S 2014+ radio (non-navi) swap into a BRZ shockingly.
I don't use the BRZ navi features, since it's slow and pretty much sucks, but my mine gripe is the lack of physical seek buttons, which the FR-S radio has.
I've purchased a used unit and it arrives in a few days. For those that are familiar, is this a direct swap? I'm worried the amp and/or power antenna wires are slightly different on the harnesses, since that's what searches seem to indicate.
So if anyone has any additional info and knows what wires if any need to be re-pinned or spliced, etc, I'd be very appreciative.
Also, when removing the BRZ radio, I plan to remove the GPS antenna as well, anything else that's no longer used and necessary?
Lord09 is offline   Reply With Quote
Old 04-27-2016, 07:58 PM   #2
Jordan Silveira
Jordan Silveira's Avatar
Drives: 2016 Subaru Series.HyperBlue #631
I'd be more than willing to swap my 2016 Series Hyperblue Head unit with yours. It has physical buttons. Just a thought.
Jordan Silveira is offline   Reply With Quote
Old 04-27-2016, 09:21 PM   #3
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I think Jordans idea is best, it's not going to be a straight swap @SVXdc is an expert on the sound system stuff, but he hasn't been online in a month so its hard to page him here. The way the BR-Z calls to power the amp on is different than the FR-S. I have the entune unit in my car and it is quite good, but it's best to either upgrade to the latest subaru unit for less of a headache.
Old 04-30-2016, 01:02 PM   #4
Lord09
Drives: 2015 BRZ
Just finished swapping over the radio and this is very simple. I like the Scion radio much more.
For those who may try this in the future, the BRZ and FRS both turn on the amp via pin 9, but the BRZ also requires power to the power antenna via pin 8. The FRS radio only sends power to pin 9, so you must send power to pin 8 by either splicing the main harness or you can purchase a reverse harness and splice the wire leading to pin 8 to the wire to pin 9.
I imagine in almost all normal situations you'd want the amp and power antenna on at all times, so if you decide to swap back to the stock radio, everything should continue to work.
**SOLD** Toyota EnTune Navigation/App module (FR-S 2014-2015) **300$** trueno86power Audio/Visual, Electronics, Infotainment, NAV 9 05-30-2016 07:05 AM
"used" EnTune nav module for 2014 touchscreen jacobzking Audio/Visual, Electronics, Infotainment, NAV 5 05-08-2016 11:25 PM
'13 FR-S base radio swap with '13 upgrade? 86868686 Electronics | Audio | NAV | Infotainment 2 06-20-2014 10:39 PM
2014 BRZ Nav radio MP3 questions Sportster Electronics | Audio | NAV | Infotainment 1 12-20-2013 08:35 PM
SOLD 2014 COMPLETE plug and play NAV head unit w/ EnTune; Pandora, Weather++ jacobzking Audio/Visual, Electronics, Infotainment, NAV 3 06-21-2013 12:32 AM
