Old 04-20-2016, 01:06 AM   #1
Zero No Densetsu
Zero No Densetsu's Avatar
Drives: 2013 Scion FRS, 1992 Nissan S13
Gram Lights 57C6
Does anyone have information regarding this SEMA 2013 Gram Lights Sponsored FRS?
Found this online but just wanted to make sure.
http://www.j-specperf.ch/index.php?m...oducts_id=3714
Im mostly interested in the specs of the wheels and tires. That fitment seems perfect and is exactly what I am aiming for. I've seen other people running the same wheels through the wheel directory but none that have a fitment as this one does.
Thank you for your help in advance.
Zero No Densetsu is offline   Reply With Quote
Old 04-20-2016, 08:11 AM   #2
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
18x9.5 +40
The Following 2 Users Say Thank You to NyC Zn6 For This Useful Post:
BirgeyT1 (04-21-2016), MisterSheep (04-20-2016)
Old 04-20-2016, 08:57 AM   #3
austinbrz
austinbrz's Avatar
Drives: 2015 BRZ Limited (Crystal Black)
57C6 Wheels Fitment
I run these wheels staggered with 18x8.5" up front and 18x9.5 in the rear. I was going to go with 255's up front and 265's in the rear and the tech from Tire Rack called me (he owns a BRZ) and told me that lowered, I would have rubbing issues in the front. He talked me into 245's in the front and keeping the 265's in the rear. I have had zero issues with that setup. For what it is worth....
austinbrz is offline   Reply With Quote
Old 04-20-2016, 10:22 AM   #4
Zero No Densetsu
Originally Posted by NyC Zn6 View Post
18x9.5 +40
Thank you!
Old 04-20-2016, 10:23 AM   #5
Zero No Densetsu
Thank you! Just read up on your build thread. Killer BRZ!!!
The Following User Says Thank You to Zero No Densetsu For This Useful Post:
austinbrz (04-20-2016)
Old 04-20-2016, 11:03 AM   #6
NyC Zn6
NyC Zn6's Avatar
Thank you!
Currently looking for a set of these as well in squared setup 18x9.5 +40. Let me know if you find some good deals.
Old 04-20-2016, 11:06 AM   #7
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
You might find some good deals here soon because I believe Rays will be redoing their whole Gram Lights series so some companies are letting their gram lights for relatively inexpensive.
Instagram: trevor.parque
NyC Zn6 (04-20-2016)
Old 04-20-2016, 03:28 PM   #8
Zero No Densetsu
For sure man, I was thinking of getting mine from evasive motorsports but will probably see if I find anything around these forums as well.
FS: Pair (2x) Rays Gram Lights 57C6 18x8.5 Ch0taku Wheels and Tires 9 07-18-2016 08:03 PM
Gram Lights 57C6 18x8.5 +35 ipsum Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 03-20-2016 11:43 AM
Gram Lights 57C6 18x8.5 +45 / 18x9.5 +40 Junkwipe Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 01-12-2015 11:22 AM
Gram Lights 57c6 DarthThinmints Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-17-2014 12:31 PM
