Old 04-16-2016, 10:31 AM   #1
all4spl
air lift install pictures?
anyone have any pictures on how they ran their air lines for the airlift? Trying to see if I should run the plastic lines in cabin or outside. Also seeing where they were mounted.
all4spl is offline   Reply With Quote
Old 04-16-2016, 05:09 PM   #2
protpibe
protpibe's Avatar
I think the easiest way to do it is to run the lines down the length of the car alongside the brake lines. They'll be protected by the plastic aero covers underneath the car. You can bring them up into the trunk area through a rubber grommet or with bulkhead fittings.
Old 04-17-2016, 07:48 AM   #3
all4spl
thanks got it all installed but now rear is clunking pretty bad :/
Old 04-17-2016, 12:49 PM   #4
Norville Rogers
Drives: Subaru BRZ
What is this? Jacks or air suspension?
Norville Rogers is offline   Reply With Quote
DIY: Air Lift Suspension Install RallySport Direct DIY (Do-It-Yourself) Guides 63 04-16-2016 11:42 PM
DIY: Whiteline Anti Lift Kit Install RallySport Direct DIY (Do-It-Yourself) Guides 7 03-13-2015 07:37 PM
Top Speed EL Header Review, Install, and Pictures tomaszjanczak Engine, Exhaust, Transmission 0 10-11-2014 07:27 PM
RAYS Gramslight 57DR - 17x9.0 +35mm 5x100 Gun Metal *** Install Pictures RavSpec Groupbuys 164 05-01-2014 09:48 AM
Pictures of Install seibon carbon Kits? kombatlion Cosmetic Modification (Interior/Exterior/Lighting) 0 02-19-2013 08:39 AM
