Old 04-16-2016, 05:22 AM   #1
Ayeitsjayson808
Drives: Toyota 86
car not starting
I tried to reflash a new file on my vishnu OFT and it turned into an error so i tried to reflash my origional map and also was an error it was currently running on a stage 2 map and i was deciding to run a different map to see the difference but all maps i tried to load were all errors. Now my frs 86 is not starting anyone knows whats the problem?
ecu wont respond for anything on the vishnu OFT.
really need help im stuck on the side of the road.
Ayeitsjayson808 is offline   Reply With Quote
Old 04-16-2016, 06:05 AM   #2
steve99
That's no sounding good.
How is your battery ? was it low or suspect.
Did you do any editing of rom or was it direct from oft downloads site ?
What were the errors you got do you remember the words.
will the oft read ecu info ?
Have you got ignition FULL on , not just accessory, without engine running.
make sure the connection to the oft and the obd port is good and pushed in correctly
Old 04-16-2016, 06:11 AM   #3
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Whats the exact error it says btw?
Old 04-16-2016, 06:15 AM   #4
steve99
Im assuming oft is powering up
The OBD ports on some cars are loose. and the data pins may not be contacting well.
Make sure plug is plugged all the way into the obd port, the bracket can bend.
Once its plugged in well, pull the plud towards you to put some sideways pressure on plug and socket see if oft will respond. If so try keeping that pressure on it for whole flash process. If that works get you obd socket in car fixed ASAP.
Old 04-16-2016, 06:24 AM   #5
Ayeitsjayson808
Drives: Toyota 86
battery is still new and is fully charged.
all i did was adjust launch control on my the file i downloaded on the oft site i tried deleteing it and tried using the pre installed maps and it pulls up saying " An error occured while writing to the ECU please try again."
the OFT does not read ecu info
ignition turns fully on.
Old 04-16-2016, 06:26 AM   #6
Ayeitsjayson808
Drives: Toyota 86
its plugged all the way in.
Old 04-16-2016, 06:27 AM   #7
steve99
ok when you were editing the launch control were the boxes in romraider green and had numbers already in them like 0 or 2000. Or were they black and blank ?
Old 04-16-2016, 06:31 AM   #8
steve99
see images at end of this post
http://www.ft86club.com/forums/showthread.php?t=79152
Old 04-16-2016, 06:34 AM   #9
Ayeitsjayson808
Drives: Toyota 86
it was green and had 2000 inside the box
Old 04-16-2016, 06:37 AM   #10
steve99
ok that sounds good.
looks like a partial flash and ecu is no longer talking to obd port.
Old 04-16-2016, 06:42 AM   #11
steve99
Try removing the positive battery terminal from car.
Then press brake to bleed off any residual power.
Reconnect positive terminal to car.
Have oft plugged in
Turn on ignition to FULL on (do not try to start car)
On first turn on of ignition try to reflash car with oft.
use you stock rom as its known good
Old 04-16-2016, 07:15 AM   #12
Ayeitsjayson808
Drives: Toyota 86
i tried it its still the same results
Old 04-16-2016, 07:21 AM   #13
steve99
mate sent you a personal message on forum
Maybe try contacting oft guys Monday, but I think ecu is bricked, either due bad edits of rom or partial flash maybe due intermittent obd connector.
you could see if oft diagnostics work on another car that will test oft, but im pretty sure its ecu.
Having troubles starting car Tomahawk Southern California 0 01-31-2016 04:13 PM
starting out dmitri93 Scion FR-S / Toyota 86 GT86 General Forum 30 07-11-2014 12:06 AM
Rev when starting ? (Possible and why ?) Simon99 Software Tuning 11 05-22-2014 04:12 AM
just starting out mortachi Cosmetic Modification (Interior/Exterior/Lighting) 3 10-06-2013 10:23 PM
Starting it off e10rice Mid-Atlantic 93 03-26-2012 03:16 PM
