Old 04-12-2016, 10:08 PM   #1
hypebrz
IG: @HypeBRZ
hypebrz's Avatar
Drives: Series.Hyperblue BRZ
Rexpeed Hood Dampers
Okay, has ANYONE successfully installed REXPEED Hood Dampers on an 86? I have tried every mounting location, every angle, every direction and every side. Nothing works and the hood will not close. The closest I got was installing the top bracket to the top 12mm mount on the hood, and the bottom to the middle 10mm bolt that holds the side fenders in place. The hood will go all way down, but right before it shuts, it hits the mount and will not close all the way. Pictures will be heavily appreciated. I contacted fr86speedfactory about detailed instructions and have not heard anything back. Searched everywhere and can't find anything!
hypebrz is offline   Reply With Quote
Old 04-13-2016, 12:00 PM   #2
hypebrz
IG: @HypeBRZ
hypebrz's Avatar
I found the mounting position, instructions are completely wrong and videos of other brands has completely different locations. Mod can delete
Old 04-14-2016, 04:49 PM   #3
Norville Rogers
Drives: Subaru BRZ
Perhaps show a picture of the mountings in case someone else has the same problem?
Norville Rogers is offline   Reply With Quote
Old 04-14-2016, 06:08 PM   #4
hypebrz
IG: @HypeBRZ
hypebrz's Avatar
The top bracket attached to the highest point of the hood mount/whatever you want to call it. The lower end, actually goes backward, opposite of other branded hood dampers the go forward. The mounting point is in the back corners of the engine bay behind the fenders.
The Following User Says Thank You to hypebrz For This Useful Post:
Norville Rogers (04-15-2016)
Old 04-15-2016, 12:01 AM   #5
Norville Rogers
Drives: Subaru BRZ
Looks good. Plenty of access
The Following User Says Thank You to Norville Rogers For This Useful Post:
hypebrz (04-17-2016)
Old 04-15-2016, 03:03 PM   #6
yefoo
Drives: 2016 BRZ CWP
Thanks for the picture. I didn't even know these existed but now I need them. -___-
yefoo is offline   Reply With Quote
The Following User Says Thank You to yefoo For This Useful Post:
Hood Dampers AlexK Cosmetic Modification (Interior/Exterior/Lighting) 8 01-20-2015 06:08 PM
FS: (BNIB) Rexpeed FRS / BRZ Carbon Fiber Hood Dampers Ricky Kwan Engine, Exhaust, Bolt-Ons 1 12-18-2014 12:45 AM
Carbon hood and hood dampers?? ft86me Cosmetic Modification (Interior/Exterior/Lighting) 15 10-19-2013 12:57 PM
FS: Rexpeed Hood dampers (brand new-ish) Kuzuri Exterior Parts (Aero, Lighting, Etc.) 1 02-11-2013 10:43 PM
Looking for Hood Dampers meant for CF hood. Vicious LED Scion FR-S / Toyota 86 GT86 General Forum 3 12-31-2012 03:47 AM
