Old 04-12-2016, 11:42 AM   #1
BDotG
BDotG's Avatar
Drives: Asphalt 2013 FR-S
What row count for oil cooler?
Having a tough time figuring this out.
Wanting to piece together my own oil cooler, but am not sure the row count of the cooler I should get.
I live in the PNW, so coldish winters (I think I will disconnect it in winter anyways) but the summers can be pretty decently hot. I daily drive the car, but will also do some auto cross and maybe 1 track day this summer.
What size cooler would you folks recommend?
BDotG is offline   Reply With Quote
Old 04-12-2016, 11:44 AM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I run a 19row
http://www.mishimoto.com/19-row-oil-cooler.html
Old 04-12-2016, 11:58 AM   #3
DarkSunrise
DarkSunrise's Avatar
It will depend on your oil temp goals, but as a point of reference, with a 13 row Perrin oil cooler (185 F thermostat and using recommended mount location) and 0w20 oil on my car, I was seeing
- track oil temps peak ~245 F in 90 F ambient
- highway oil temps hover ~175 F in 65-70 F ambient (using my front license plate as a partial block-off)
I'm switching to 0w30 oil this year so my oil temps will probably elevate some. Ideally I'd want highway temps just a little higher and track temps a little lower, but the 13 row seems to be a good compromise in my experience (for NA). If you have FI, you'll almost certainly want a bigger cooler.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
BDotG (04-12-2016)
Old 04-12-2016, 12:33 PM   #4
BDotG
BDotG's Avatar
Yeah, I am NA. I want to switch over to 5w30 for the summer so not sure what/if any effect that will have on the cars overall pressure/temp. I think ill go with a 13 row as I just need that little bit of cooling.
Old 04-12-2016, 02:12 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Oil temp goals will dictate what kit you should run. Size of core is not as important as airflow over it + ambient temps.
Case in point: you could run a small core that is better for street. Wire up your own electric fan setup so that it pulls air behind it. Run ducting so it is cooled sufficiently at the track.
-alex
Old 04-12-2016, 02:27 PM   #6
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Honestly, from your use case I don't think you need an oil cooler. Catch can would be my recommendation.
But to answer your question, I have the Mishimoto one as well. Do about 3-4 track events a year.
Jyn is offline   Reply With Quote
The Following 2 Users Say Thank You to Jyn For This Useful Post:
BDotG (04-12-2016), go_a_way1 (04-12-2016)
Old 04-12-2016, 02:31 PM   #7
mav1178
mav1178's Avatar
If you must run an oil cooler, consider the OEM Forester or Cusco type design for cooler climates.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
BDotG (04-12-2016)
Old 04-12-2016, 02:51 PM   #8
BDotG
BDotG's Avatar
-alex
I've considered it, although I've heard they don't really do much in the way of cooling? More like warming the oil up quicker and keeping it like somewhatish stable.
Old 04-12-2016, 02:54 PM   #9
mav1178
mav1178's Avatar
I had a Cusco cooler before I swapped out to an external core cooler.
It is good enough for what you want to do. I estimate my oil temps hover around 125-130C max with the cooler (in desert, heat-soaked conditions).
About 10-15C reduction from stock. It's not going to be as effective as an external setup but frankly for what your stated goals are, you won't really need one.
Autocross won't put that much heat in the oil... keep in mind the key factor in oil temps is not ambient heat, it's RPM. Ambient temps are only relevant if you have an external source of cooling the oil or if you are overworking the cooling system.
-alex
Old 04-12-2016, 02:58 PM   #10
Jyn
Noob
Jyn's Avatar
Forrester XT oil "cooler" is not useful for track/high performance driving environments. Like stated, it mostly just brings oil to temp.
Old 04-12-2016, 03:01 PM   #11
mav1178
mav1178's Avatar
Are you speaking from experience or just what others have said?
I ran the Cusco setup on my car for the last 2 years and while it is not as effective as a standalone oil cooler, it was enough to keep temps in check and never over 130C, even at Chuckwalla Valley Raceway in 115F ambient temps.
-alex
Old 04-12-2016, 03:04 PM   #12
BDotG
BDotG's Avatar
I think I will give the OEM style one a shot and see how that goes. I know NED sells them for like $225. Will see how that treats me.
Old 04-12-2016, 03:43 PM   #13
Jyn
Noob
Jyn's Avatar
Research I did when looking for solutions for HPDE events, so yes, not firsthand experience. It's pretty well documented on the forum.
Old 04-12-2016, 03:52 PM   #14
DarkSunrise
I like the recommendation of the liquid-to-liquid OEM-style cooler for you being in the PNW. It'll warm up the oil faster in the cold, and will be sufficient cooling for autocross and the occasional track day. I think that's the way to go.
2022 BRZ Build
2013 FR-S Build
Transient ignition and knock count brn12345 Software Tuning 19 06-10-2014 11:46 PM
Final production count? Jawnathin BRZ First-Gen (2012+) — General Topics 0 08-01-2013 09:57 PM
post count VENOM~ Site Announcements / Questions / Issues 19 10-08-2012 05:13 PM
WE NEED A COUNT DOWN!!! carbonBLUE Scion FR-S / Toyota 86 GT86 General Forum 26 01-20-2012 05:07 PM
