Old 04-06-2016, 09:14 PM   #1
86Tony
Drives: 2015 AOZORA EDITION
help kw clubsports
hey i have some clunking in my passenger rear, it only happen when driving slow on bumps or when i hit bigger dips. im trying to figure out my issue everything is tq down right and i have double checked everything and it still clunk. i recently swap my top hats to the raceng one since i thought it could of been worn out top hats but that didnt fix it and i notice it more now. should i swap my passenger to my right side and see if its my shock or if its suspension thats making noise?
86Tony is offline   Reply With Quote
Old 04-06-2016, 10:49 PM   #2
mpross
mpross's Avatar
Drives: 2015 Scion FRS
Subscribing. Same issue with different coilovers
Sent from my SAMSUNG-SM-G928A using Tapatalk
mpross is offline   Reply With Quote
Old 04-11-2016, 01:03 AM   #3
86Tony
bump.... can a damper even make clunking noises? like on smooth roads it rides beutifuly but once it gets.bumpy i start hearing the clunk. dampening still feels good
Old 04-11-2016, 08:05 AM   #4
Tor
Tor's Avatar
Drives: Toyota GT86
Did you check your sway bar endlinks?
You could disconnect them from the lower control arm. If the noise stops, it has to be swaybar related. If it doesn't at least you excluded that possibility.
Tor is offline   Reply With Quote
The Following User Says Thank You to Tor For This Useful Post:
strat61caster (04-11-2016)
Old 04-11-2016, 12:39 PM   #5
86Tony
will try that out i did swap the suspension 4 times so maybe the endlinks are worn out. finger crossed and hopefully its that. will report back when i try it.
KW Clubsports Review kanundrum Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 03-14-2016 10:49 AM
KW & ST Suspension | V3 | Clubsports 2-Way & 3-Way | Free Shipping!! Kami Speed Brakes, Suspension, Chassis 34 08-31-2015 03:46 PM
KW CLUBSPORTS!! FREE SHIPPING, BUY THEM AND GET $100 GIFT CARD! @PURE Pure Automotive Brakes, Suspension, Chassis 13 04-07-2013 08:17 PM
