12% Done with the car.
Drives: FRS
Coilover question for those running RCE Tarmac II's
I bought a set used a while back and have had no problems with it thus far, but I noticed something a little weird on the rear suspension. I'm running raceseng rear shock top hats in the rear if it makes any difference, but the springs are compressed all the way down at the top.I was just wondering if it's normal to be compressed like that.
HOUSTON TEXAS FR-S/BRZ OWNERS - https://www.facebook.com/groups/houston86/
Drives: FRS
Drives: 2014 BRZ Sport-tech
Pretty sure that's normal and mine look like that too.
@Racecomp Engineering |
| The Following User Says Thank You to infinity21 For This Useful Post: | enjoi23 (04-04-2016) |
Drives: 2017 BRZ
That's the helper spring - if you were to lift the rear of the car you'd likely see that expand to take up the slack once there's no weight at all on the rear suspension and it's fully extended.
| The Following 3 Users Say Thank You to cjd For This Useful Post: |
Drives: 13 GBS BRZ
Yep, like CJD said, that's the helper spring. It's supposed to be like that.
| The Following User Says Thank You to Porcupint For This Useful Post: | enjoi23 (04-04-2016) |
Drives: 2014 BRZ SCCA STU endurance car
Totally normal, those are helper springs that can be compressed very easily, they help take up droop when the suspension unloads.
| The Following User Says Thank You to Gear_One_Performance For This Useful Post: | enjoi23 (04-04-2016) |
The Stig's German cousin
Yup. Without the tender spring, if that corner became fully unloaded the main spring might not be seated properly when everything compressed back to normal.
| The Following User Says Thank You to renfield90 For This Useful Post: | enjoi23 (04-04-2016) |
Drives: FRS
Awesome just checking. Better to be safe than sorry. Thanks guys!
Normal.
![]() Sorry just saw your PM, I'm out of the country. - Andrew |
| ***FT-86 SpeedFactory RCE Tarmac 2 Clubsport and Tarmac Zero Sale Thread*** | FT-86 SpeedFactory | Brakes, Suspension, Chassis | 208 | 09-30-2016 03:43 PM |
| RaceComp Engineering Tarmac Coilover sale | Racecomp Engineering | Brakes, Suspension, Chassis | 1 | 11-02-2015 10:08 AM |
| coilover question | Sketchi | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 09-27-2014 06:00 PM |
| Racecomp Tarmac II Clubsport coilover | JoeBoxer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 47 | 11-16-2013 11:02 PM |
