Old 04-03-2016, 09:17 PM   #1
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Boost controller help
If anyone could help me out that would be great. I am looking to fit a manual boost controller to my car. The turbo has an adjustable internal waste gate and currently I experience some creep that i am uncomfortable with. So I will be getting the turbo ported I guess and I was looking into some other ways to prevent the creep and control the boost better.
So I was looking at this boost controller
http://www.turbosmartdirect.com/Prod...Tee-Black.html
So for installing it on a car with an adjustable Internal W/G. Would I just adjust my W/G All the way as low as possible and use the boost controller to set my target boost? Most turbos I have worked with before(S15 SR20 turbo for example) where it had a fixed rod and I would just Run the boost controller in line and set boost with that.
I am sorry if im not very clear with my question but any help would be appreciated.
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 04-04-2016, 07:56 PM   #2
NahumCC
Drives: 2013 FR-S 10 Series
I would set your wastegate at whatever it's default is that way you have a known baseline to know where your adjusting from with the MBC.
Sent from my SAMSUNG-SM-G870A using Tapatalk
NahumCC is offline   Reply With Quote
The Following User Says Thank You to NahumCC For This Useful Post:
nickmerronesucks (04-04-2016)
Old 04-04-2016, 08:12 PM   #3
nickmerronesucks
Ned flanders
Thanks I over thought the whole thing. I'm going to readjust my wastegate so that it has some preload and then install the boost controller.
797Performance.com
The Following User Says Thank You to nickmerronesucks For This Useful Post:
NahumCC (04-04-2016)
Old 04-05-2016, 01:26 PM   #4
denso
Drives: 86
You can not go under the wg spring pressure. If you minimal boost is set at 5psi you wont be able to go lower than that.
If your wg is adjustable I would go with the lowest wg spring pressure thats possible.
denso is offline   Reply With Quote
Electronic Boost Controller BRZtoni Forced Induction 9 01-21-2018 01:38 PM
Digital boost gauge w/ vent pod grim speed boost controller Meetjoeblack Engine, Exhaust, Bolt-Ons 0 03-09-2015 01:27 PM
Turbos/boost controller Anthony7515 Engine, Exhaust, Bolt-Ons 2 11-20-2014 03:48 PM
Turbosmart E-boost controller Fl4t fun Engine, Exhaust, Bolt-Ons 0 01-29-2014 11:29 PM
