Old 04-03-2016, 03:54 PM   #1
ndsleep612
Drives: Thee Argento Cricket
Updating OEM Navi
I have an 2013 OEM head unit with Navi for my FR-S and have been having trouble inputting some addresses for directions. Some addresses simply doesn't exist for the older Navi head units. Does anyone know if it's possible to find/get an updated flash for the Navi unit? Thanks
ndsleep612 is offline   Reply With Quote
Old 04-03-2016, 05:27 PM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
The maps are $160+ and can only be updated at dealerships, I have the same navigation as well, and because the car is now 3 years old in your case its quite worth it if you use it a lot. In my case the Harman OEM unit came out of a 2012 prius and has the latest firmware but not the latest maps so the issue for me is much greater. The dealership can only update it due to the fact they seem to have learned about navigation piracy Basically they have to activate the license through tech stream and also they have a specific usb drive that ONLY updates through techstream, also it asks for the technicians name and ID number stuff
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
ndsleep612 (04-03-2016)
Old 04-03-2016, 10:36 PM   #3
ndsleep612
I was afraid this might be the answer. Greatly appreciate the help.
Old 04-03-2016, 11:49 PM   #4
FRSBRZGT86FAN
I know its a weird thing to save up for but you probably should, the latest maps also update the logic of how the system reroutes, I'm saving for it on the side a bit to pay for the update.
Old 04-04-2016, 02:05 AM   #5
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Damn, didnt realize that its such a pain for the FRS.
Either way, I plan on just replacing my headunit with one that supports Android Play, like the new JBL one. Its only $400 and you can use Google Maps or Waze with it, rather than relying on outdated maps.
Just my opinion.
PandaSPUR is offline   Reply With Quote
Updating the stock tune on the OFT Dawan Software Tuning 5 03-04-2016 08:11 PM
Updating OFT tunes? Kerune Software Tuning 1 07-07-2015 01:30 AM
DIY-- How to bypass your NAVI without moving out your NAVI (Canadian BRZ only) 8987846 DIY (Do-It-Yourself) Guides 77 04-29-2015 02:45 PM
Bypassing your NAVI without moving out your NAVI 8987846 CANADA 0 12-24-2012 03:20 AM
Scion.ca down - updating? Sport-Tech CANADA 8 04-05-2012 04:00 PM
