Old 03-31-2016, 01:41 AM   #1
RavenFish
Drives: 2016 Raven FR-S
Berk Dual Exit Muffler Delete on a 2016 FR-S?
Hey everyone, i have a question, i was going to buy the Berk Dual Exit Muffler Delete from www.moddiction.com but it says it only fits 13-15, can anyone confirm that it will fit my 2016 FR-S before I buy it... Thanks Everyone
RavenFish is offline   Reply With Quote
Old 03-31-2016, 01:42 AM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
It will definitely fit, it's literally two 14 mm bolts to remove and 4 exhaust hangers. You then transfer over 2 hangers to the berk and use the included gasket and 15 mm bolts and nuts they supply. You will a breaker bar or a good ratchet and a pipe that fits over the handle, the hardest part was removing those two bolts and I only had, had the car for 3000 miles at the time of install and they were torqued on real tight probably from the heat
Old 03-31-2016, 01:44 AM   #3
RavenFish
Do you have any idea why they say it wouldn't fit ?
Old 03-31-2016, 02:20 AM   #4
FRSBRZGT86FAN
They are super behind on what they list as compatible there is no reason the muffler delete shouldn't fit. The exhaust system is the same for all the years 2013-2016 there's been no change whatsoever I can guarantee it. I used to own this exhaust I can tell you it barely passes off as an exhaust system It's a pipe with two holes and no muffler and it only really sounds good and not droney if you don't mod the rest of the exhaust
Old 03-31-2016, 02:35 AM   #5
RavenFish
Is it good, did you have any trouble with police'?
Old 03-31-2016, 02:39 AM   #6
FRSBRZGT86FAN
In PA I had no problems. @Pat.Thornton has it now and so do many others. It's not illegal loud it sounds very very good over stock and is much louder, but because you're in California they may be more strict about noise. In PA it's a bit below the 90 decibel sound limit if anyone were to check, but as soon as you get a UEL or EL, or front pipe, or mid pipe it will get louder to the point that legality may be a concern. If it's kept with a stock system and just the berk you'll be fine.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
RavenFish (03-31-2016)
Old 03-31-2016, 02:53 AM   #7
RavenFish
Thanks a lot Buddy I aprreciate it
The Following User Says Thank You to RavenFish For This Useful Post:
FRSBRZGT86FAN (03-31-2016)
WTB berk dual exit muffler delete Derrick Want-To-Buy Requests 7 10-08-2014 02:10 AM
WTB BERK DUAL EXIT MUFFLER DELETE 1slowfrs Want-To-Buy Requests 0 07-11-2014 03:42 PM
Where to buy Berk dual exit muffler delete? aakash Engine, Exhaust, Transmission 8 06-12-2014 11:14 AM
FS: Berk Dual Exit Muffler Delete bcmakesiteasy Engine, Exhaust, Bolt-Ons 5 05-01-2014 03:45 PM
WTB: Berk Dual Exit Muffler delete ProjectBrz Want-To-Buy Requests 0 04-21-2014 09:24 PM
