Old 03-30-2016, 03:43 AM   #1
JasonXieyf
Drives: 15BRZ
Porterfield R4S for track use?
Hello
I just wore out my first set of track pad, ProjectMu HC800, after 5 track days.
I'm satisfied with the pmu hc800, significant performance increase over stock pad and doesn't seem to fade in a 15-minute section.(I usually don't run the whole session)
I'm looking for next set of brake pads. Ideally the PMU Club Racer is the best choice(many of my friends are using that), but the price is a little high and it seems to wear out quicker on the street.
A friend of my who tracks his RX8 recommends me Poterfield r4s for track use. According to his feedback those pads are solid for track use. But when I was searching there are different comments on this pad. Some say it is good, the others say it is a piece of trash for track, and fades easily.
Or I can just buy another set of HC800.
Just want to know if there is anyone running these pads on their FRS/BRZ for track/street duty. Thanks
JasonXieyf is offline   Reply With Quote
Old 03-30-2016, 04:55 AM   #2
Apex-Apex
Apex-Apex's Avatar
I ran the R4 on the track and they're pretty good. I heard R4S is their street pad and might not last as long.
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline   Reply With Quote
Old 03-30-2016, 05:15 AM   #3
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Not related to these pads in particular but pads in general.
The same brake pad is not the same thing to all people. Different people brake differently, have different cars, use them at different tracks. The requirements for a tight slow track are different from a fast open track. The situation is further complicated if you are using the same pad for street and track.
Old 03-30-2016, 12:40 PM   #4
R4 is great on track. R4S is a street pad, and is not appropriate for track use.
Just bite the bullet and step up to Club Racers. You won't regret it once they're on the car.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
DarkSunrise (03-30-2016), go_a_way1 (03-30-2016), LOLS2K (03-30-2016), Toyarzee (03-30-2016)
Old 03-30-2016, 01:00 PM   #5
DarkSunrise
DarkSunrise's Avatar
Hello
I had a similar issue with my PMU HC+800's wearing out after 4 track days. I never really liked them to be honest. There are much better pads out there for track use. I switched to Carbotech XP10's and they've been a big improvement. I would recommend Carbotech XP10 or XP12, or PMU CR's as Mike recommends.
One warning - it was after I switched to XP10's that I started melting my stock brake piston seals. The pads can take a good amount of heat, but you may start to find weak links elsewhere in the stock brake system.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
LenA (03-30-2016)
Old 03-30-2016, 01:06 PM   #6
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
First I've read of someone having this problem. That doesn't sound good at all... PMU CR's here and I haven't had any regrets yet. Did you replace the whole brake system or target only certain conponents to combat heat in other areas?
Toyarzee is offline   Reply With Quote
Old 03-30-2016, 01:18 PM   #7
Totally normal to melt/burn the outer seals once you step up to race pads. Totally okay to drive without those seals, provided you don't drive in a salted area.
My S2k has been seal-less for ~6 years now.
Old 03-30-2016, 03:05 PM   #8
DarkSunrise
It's pretty typical to have this issue and not a huge issue from what I've heard. I just noticed abnormal taper on my pads and found that my seals had melted, causing the pistons to stick. I upgraded to a BBK mostly for peace of mind (wanted something designed for track abuse and cheaper pads), but as Mike said, I could have just removed all the seals too.
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
CSG Mike (03-30-2016), Toyarzee (03-30-2016)
Old 04-01-2016, 07:49 PM   #9
darkonion
Habitual Troublemaker
darkonion's Avatar
Drives: 1997 Subaru Impreza, 2014 BRZ
This was awhile ago, 2009ish, but I ran the R4S for two track days on my old Impreza. At least from my experience, they seemed to be okay for the track. Of course, different car, different track, different driving style.
Car: 1997 Subaru Impreza
Track: Thunderhill
Driving Style: Slow
darkonion is offline   Reply With Quote
Old 04-02-2016, 09:06 AM   #10
Captain Snooze
Drives: Red Herring
You are melting the boots not the seals.
DarkSunrise (04-02-2016)
Old 04-02-2016, 11:25 AM   #11
DarkSunrise
Attachment 134728
Ah you're right, good catch. Meant to say dust boots.
2022 BRZ Build
2013 FR-S Build
Old 04-02-2016, 12:47 PM   #12
Traktor
Drives: Subaru BRZ Limited
I had a similar experience with the HC800s. They didn't fade after 20 minute sessions and are about 2/3 worn after 3 track days.
They work well on the street, but the downside is a lot of brake dust!
I'm switching to an Essex Sprint kit up front, 07 WRX 2 pot rear with Carbone Lorraine RC5+ pads all round.
Traktor is offline   Reply With Quote
dp1 track build (NY) dp1 NY / NJ / CT / PA 114 07-19-2017 02:47 PM
Hawk HP and Porterfield R4-S Brake Pads in SoCal RJ80 Brakes, Suspension, Chassis 2 03-16-2014 09:41 PM
MVP Track Time 2013 Great Lakes/Midwest Track Dates Feffman Great Lakes 5 09-07-2013 02:39 PM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs NY / NJ / CT / PA 11 08-21-2012 12:31 AM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs Tracking / Autocross / HPDE / Drifting 0 08-14-2012 07:46 PM
