Old 03-28-2016, 07:57 PM   #1
SVLTE
Whiteline 16mm rear bar, SPC LCA's w/ STX legal bushings
For Sale:
Whiteline 16mm rear bar w/ adj. endlinks and braces - $250
SPC LCA's w/ unused DIF STX legal bushings - $200
Parts are located in Pittsburgh, PA. Prices do not include shipping.
SVLTE is offline   Reply With Quote
Old 03-28-2016, 09:19 PM   #2
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Do you have the stock SPC bushings as well?
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 03-29-2016, 12:44 AM   #3
SVLTE
No, if you just want regular SPC arms I'm sure you can find them a bit cheaper. The SPC spherical bearings have a rubber boot that I wasn't able to keep from tearing when I pressed them out.
Bushings are brand new and were just pressed in today. The arms have just 41 autocross runs on them. This is the same setup FRSport charges $300 for:
http://www.frsport.com/DIF-10595-Rea..._p_445910.html
Old 03-29-2016, 08:38 AM   #4
JazzleSAURUS
Awesome, very helpful actually.
Is the advantage of the DIF bushing just a Delrin replacement bushing instead of the soft rubber?
Thanks!
Old 03-29-2016, 08:56 AM   #5
SVLTE
The only advantage really is that they are class-legal for SCCA Street touring because the OEM LCA's use a bushing, so the aftermarket ones must also use a bushing even if it's delrin. Since the SPC arms technically use a spherical bearing (the soft rubber is just the boot that protects the joint like on your axles) they are not considered legal for that class without these bushing replacements. Hope that helps!
Old 04-07-2016, 11:41 AM   #6
SVLTE
Bump!
Old 04-08-2016, 12:41 AM   #7
phongtphan21
Drives: 2013 Fr-s
How much for both with shipping would you do a deal ?
Sent from my SM-N920T using Tapatalk
phongtphan21 is offline   Reply With Quote
Old 04-08-2016, 11:13 AM   #8
SVLTE
How about if you buy both I'll ship them for free? Ill PM you... lets make a deal.
Old 04-09-2016, 04:03 PM   #9
TruRace
TruRace's Avatar
Drives: FRS-Raven-MT
LCA's still available?
TruRace is offline   Reply With Quote
Old 04-10-2016, 12:53 AM   #10
MrFisty
The Fistiest
MrFisty's Avatar
Drives: 2013 Argento FR-S
I'm highly interested in LCA's. Would like to discuss shipping to 39759.
They said my last sig was too big.
MrFisty is offline   Reply With Quote
Old 05-29-2016, 12:41 PM   #11
phaMR2
Drives: 2014 BRZ Limited
For Sale:
Whiteline bar still available?
phaMR2 is offline   Reply With Quote
FS: OEM 16mm WRX rear sway bar w/Whiteline bushings norcalpb Brakes, Suspension, Chassis 13 01-20-2015 05:10 PM
Whiteline 16mm rear adj swaybar toeout Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 07-28-2014 11:03 AM
Whiteline Rear Camber Bushings wootwoot Brakes, Suspension, Chassis 2 10-29-2013 12:16 AM
