Old 03-25-2016, 01:45 AM   #1
RacerX661
Drives: 13' FR-S
E85 log help
Hey just got a open flash tuner the other day and just got some E85 left it on stg 1 for around 3-4 miles then switched to stg 2 el e85 tune drove it slow for about 30-35 miles before I went over 3500RPM
took some logs can you guys check them out to see if everything is ok?
and also what should I be looking for?
http://www.datazap.me/u/racerx/e85-t...=1-7-8-9-10-11
http://www.datazap.me/u/racerx/e85-f...=1-7-8-9-10-11
RacerX661 is offline   Reply With Quote
Old 03-25-2016, 04:45 AM   #2
steve99
looks fine no knock, fuel trims ok ,bit rich at higher rpm, probably need to tweak the open loop maf scaling to fix it, but nothing drastic
read the links below on ecu logging
