Old 03-20-2016, 09:27 PM   #1
ft86me
ft86me's Avatar
Drives: 2013 FRS
FS: used Perrin oil cooler
SOLD !!!
Selling my used Perrin oil cooler. Used it for about a year and a half and no longer need it due to a company giving me one. Works perfectly fine with no issues. Perrin sells this new for 670.00. I am asking 350 OBO. Send me your offers if you are thinking of a lower price. About half off.
Oil cooler has been washed out and flushed out by a radiator shop after being removed from the car.
Note:
up to you , but you may want to purchase the two gaskets for the thermostat and the cooler spacer. Those are rather inexpensive. I mention this because anytime you change something in the automotive industry with a gasket , it's recommended to replace them as we do at my shop. Your choice in the end.
Also , the m6x10 x4 Allen head bolts are not available through this sale. You can purchase them through Perrin or Home Depot. You will need m6 washers with those. Again, all very inexpensive.
Lastly, the shielding for the oil lines do so signs of rips in them. In no means are the oil lines damaged. The kinds are perfectly fine. The rips are not visible once installed since they face down. You can also replace these if you like which again are very inexpensive.
After obtaining the replacement parts such as the bolts , gaskets, and even the shielding which don't need to be replaced , you'll be well under the price of a new unit. Hence the half pricing.
there are slight rips here in the heat repelling sleeve. Actual oil line is NOT damaged.
oil hose is not damaged. There are no leaks from here.
Any questions , pm me or get a hold of me on ig : boostedgt86
ft86me is offline
perrin oil cooler Bluetail Engine, Exhaust, Bolt-Ons 21 10-29-2018 02:41 AM
Perrin Oil Cooler zdr93523 Engine, Exhaust, Bolt-Ons 8 06-26-2015 12:35 PM
FS: Perrin Oil Cooler (new) b34ny Engine, Exhaust, Bolt-Ons 21 11-03-2014 11:10 AM
FS: Perrin Oil Cooler Nhil Engine, Exhaust, Bolt-Ons 7 05-28-2014 09:39 PM
Perrin Oil Cooler D1cker Engine, Exhaust, Bolt-Ons 13 05-08-2014 12:41 PM
