Old 03-19-2016, 12:24 PM   #1
Kenshiki
Drives: 2013 firestorm red FRS
intake and radiator suggestions
long story short i got in an accident.... i rear ended someone, it was a Rav4 and nothing happened to his car. Mine on the other hand, the whole front end got unhinged and my hood got folded up.
Anyway the shop is telling me i need a new radiator and a new air box (among other things), says the fan is still good. Now im thinking of going with a RKsport short ram air hood. Im not really sold on it yet but im looking for suggestions on a new intake and new radiator. The hood says its has the outlet where the stock airbox is, so im looking more at systems that use the same position in the engine bay.
Im thinking of going with a Injen Sp short ram system with a koyo radiator, im wondering if anyone has had any experience with these products and if they work well together
Alternately i was thinking of going with a Mishimoto radiator and cold air intake, and have the same question. Im assuming since they are from the same company, they would work well together
Any suggestions on a better setup?
My last question is, if i got aftermarket with the radiator do i have to upgrade my fans as well or should the stock still do the job?
(This is my first time creating a post so i hope i put it in the right section)
Kenshiki is offline   Reply With Quote
Old 03-19-2016, 03:37 PM   #2
15limited
15limited's Avatar
Koyorad fits in stock location with stock fans, I didn't have any fitment issues. When I was researching I found mixed results with the Mishimoto radiator.
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
The Following User Says Thank You to 15limited For This Useful Post:
Kenshiki (03-23-2016)
Old 03-19-2016, 05:06 PM   #3
cjd
cjd's Avatar
Drives: 2017 BRZ
Unless you're able to rescale MAF, Grimmspeed is the only aftermarket intake I'd recommend. It also does quite well considering how little gain there is to be found in an intake.
The Following 2 Users Say Thank You to cjd For This Useful Post:
Kenshiki (03-23-2016), Wayno (03-19-2016)
APR CARBON FIBER RADIATOR COOLING PLATE FOR TRD INTAKE Oakley Engine, Exhaust, Bolt-Ons 6 12-27-2015 01:56 PM
New Release - Samco New Colors - Radiator, Heater, and Intake Hoses. FT-86 SpeedFactory Engine, Exhaust, Transmission 1 08-26-2015 11:48 AM
FS: OEM Exhaust, Radiator, Intake Tube, Sound Generator, Windshield Fluid Reservoir zeal86 Engine, Exhaust, Bolt-Ons 5 07-25-2015 08:42 PM
Intake and Cat Back Suggestions dray551 Engine, Exhaust, Transmission 6 03-10-2015 10:33 PM
APR Radiator Cooling Plate Carbon Fiber w/ TRD Intake Subaru BRZ 2013-2014 / Scion FR RallySport Direct Engine, Exhaust, Bolt-Ons 0 02-27-2014 05:25 PM
