Old 03-18-2016, 11:28 PM   #1
lupindub
Drives: Scion FR-S
Is there a certain order in removing the under panel's?
So it seems like some of the under panels are over lapping each other and wondering if there is a certain order you have to take it apart. For example do you have to remove panel #2 before removing panel #3? I also recall a piece of panel #2 overlapping panel #1 but I might be mistaken.
lupindub is offline   Reply With Quote
Old 03-19-2016, 12:17 AM   #2
Uplink
Uplink's Avatar
Drives: anything you let me
Depending on what you're doing, you don't necessarily have to completely remove the other panels, just the fasteners from it that hold the panel you want to access if applicable. ie, Between 2 & 3 there's some fasteners I believe that go through both. Remove those and 3 will slip free. Not sure what model you have but mine (US Spec FR-S) doesn't have panel #4 that I recall ever seeing.
Uplink is offline   Reply With Quote
Need help removing panel under read window (where the brake light is located) JoshVDS01 Cosmetic Modification (Interior/Exterior/Lighting) 1 01-24-2016 11:00 PM
DIY 5 Panel Wink Mirror install WITHOUT removing visors bizintine DIY (Do-It-Yourself) Guides 31 09-09-2015 12:22 AM
Removing panel above instrument cluster inio DIY (Do-It-Yourself) Guides 3 08-09-2015 02:34 PM
Dented rear wheel side panel/rocker panel. Autocon Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 19 12-22-2014 11:18 PM
Norcal Trade: My FR-S Panel for BRZ Panel VakaGT Exterior Parts (Aero, Lighting, Etc.) 9 07-20-2014 06:23 PM
