Old 03-07-2016, 02:53 PM   #1
EssJay
Drives: '16 FR-S Halo White
Understeering with Grimmspeed front bar
Just installed the Grimmspeed front tower bar. It's tough to tell yet if it feels sharper/more responsive but I definitely sense the understeer now. I'm wondering if a rear bar would correct this and restore the neutrality? Any other suggestions? It's a lease so I can't go too crazy.
EssJay is offline   Reply With Quote
Old 03-07-2016, 02:55 PM   #2
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Camber bolts and a front-end alignment. You can probably get to around -1 to -1.5 degrees with just camber bolts, which will be a nice improvement over the stock alignment.
jawn is offline   Reply With Quote
The Following 5 Users Say Thank You to jawn For This Useful Post:
Cole (03-07-2016), EssJay (03-07-2016), go_a_way1 (03-07-2016), Racecomp Engineering (04-12-2016), strat61caster (03-07-2016)
Old 03-07-2016, 03:12 PM   #3
EssJay
Sounds good but I'm not sure I want to alter/accelerate the treadwear. Looking to keep these Primacy summer rubbers for the duration of the 3yr lease period if possible (a guy can dream)
What about just adding the rear bar?
Old 03-07-2016, 03:18 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Rear bar will only tighten the rear end up (less slop). I dont think your strut bar is making your car under-steer. It always did that but now that you added the bar you are driving into the corners harder and its just the placebo effect
The Following 5 Users Say Thank You to go_a_way1 For This Useful Post:
Calum (03-07-2016), Cole (03-07-2016), EssJay (03-07-2016), strat61caster (03-07-2016), wparsons (03-07-2016)
Old 03-07-2016, 03:24 PM   #5
Cole
Not a troll
Cole's Avatar
Yeah, strut bars (front and rear) don't do a whole lot except for make you believe you can take a corner faster. It's not that the bar has made things that much stiffer, it's that you believe it did, so you're able to push more without that mental block kicking in.
1 or 2 degrees of negative camber shouldn't prematurely wear your tires down, either.
The Following 3 Users Say Thank You to Cole For This Useful Post:
EssJay (03-07-2016), go_a_way1 (03-07-2016), wparsons (03-07-2016)
Old 03-07-2016, 03:27 PM   #6
shellslinger
Drives: Whiteout FRS
I think toe effects tire wear more than camber.
shellslinger is offline   Reply With Quote
The Following 3 Users Say Thank You to shellslinger For This Useful Post:
Old 03-07-2016, 03:39 PM   #7
strat61caster
strat61caster's Avatar
If you're not tracking/autocrossing/drifting the mountain pass or doing >15k miles/year the Primacy's will last. -1.5 degrees of camber won't change that. Mine made it to 30k over about 2 years and I got rid of them because I thought the grip was gone for track/autox purposes (2x HPDE's, ~4x autox). They would have been fine for another year to 45k no problem even with more autox/track abuse.
go_away is right, the car understeered before, you just weren't hard enough into the corners to feel it until now.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Cole (03-07-2016), jawn (03-07-2016)
Old 03-07-2016, 03:45 PM   #8
jawn
jawn's Avatar
Rear bars aren't going to help much. I've had cars that had OEM alignment specs at -1.5 camber and never had a tire wear issue. Just make sure your toe is within factory specs and you'll be fine.
Old 03-07-2016, 03:49 PM   #9
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
The strut bar didnt cause the understeer. This car understeers from factory. Add -1.5 camber up front and itll go away. Keep 0 toe and it'll be good for 3 years assuming you dont have a 45k mile lease lol
The Following 3 Users Say Thank You to finch1750 For This Useful Post:
Captain Snooze (03-10-2016), EssJay (03-07-2016), wparsons (03-07-2016)
Old 03-07-2016, 03:50 PM   #10
finch1750
finch1750's Avatar
exactly. see my sig
Cole (03-07-2016), DustinS (03-08-2016), go_a_way1 (03-07-2016)
Old 03-07-2016, 03:56 PM   #11
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
exactly. see my sig
LOL yeah I remember reading that a while back and laughing my ass off.
Old 03-07-2016, 04:07 PM   #12
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
How often do you drive your car?
Old 03-07-2016, 04:55 PM   #13
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Learning to drive my car fixed my understeer issues. This is even on a staggered setup with stock alignment. I don't understand why it's always the car's fault on this forum.
Where are you driving the car to experience this? How are you managing brakes, gas, and steering?
The Following User Says Thank You to boredom.is.me For This Useful Post:
e1_griego (03-07-2016)
Old 03-07-2016, 05:02 PM   #14
projek_01
projek_01's Avatar
Drives: 1996 ST204, Series 10 FR-S
I'm not expert but I find that keeping my foot on the gas early on in corner helps with the under steer dramatically. Quite different to drive compared to a FWD Celica I used to drive.
projek_01 is offline   Reply With Quote
The Following User Says Thank You to projek_01 For This Useful Post:
EssJay (03-07-2016)
FS: Grimmspeed Front Tower Strut Bar ThatBlueBRZ Canada Classifieds 1 07-21-2015 12:06 AM
Grimmspeed front plate relocation kit vroom4 Exterior Parts (Aero, Lighting, Etc.) 15 01-25-2015 07:53 PM
GrimmSpeed front license relocation Blastersix Exterior Parts (Aero, Lighting, Etc.) 1 01-02-2015 04:29 PM
[WA] Grimmspeed front strut bar - red Fizz Australia Classifieds 0 12-02-2014 03:33 AM
Grimmspeed Front Strut Bar Vlady Engine, Exhaust, Transmission 3 04-23-2014 02:46 AM
