Old 03-05-2016, 01:40 PM   #1
surfdontswim
surfdontswim's Avatar
Drives: 2013 Scion FR-S Firestorm
Greddy EVOlution GT exhaust install
For those of you who have installed this exhaust. Did you use the factory donut gasket? According to Greddy, this should be replaced with their special composite gasket and bolts, replacing the factory spring bolts and donut. However, ft86speedfactory and fteightysix say to use the spring bolts and donut. What did you do when installing? The Greddy flange would have to have a concave flange to accept the donut.
surfdontswim is offline   Reply With Quote
Old 03-05-2016, 02:08 PM   #2
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
I used the factory one with my 3" JDL D2 exhaust
Sent from my SAMSUNG-SM-N920A using Tapatalk
texasbound972 is offline   Reply With Quote
Old 03-06-2016, 10:54 AM   #3
Apex-Apex
Apex-Apex's Avatar
No, you reuse the hardware that comes with it. You take out the OEM donut and replace it with the matte grey thick gasket and the two supplied sets of bolts and nuts.
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline   Reply With Quote
The Following User Says Thank You to Apex-Apex For This Useful Post:
eastendraceshop (08-30-2019)
Old 03-06-2016, 09:46 PM   #4
surfdontswim
Thanks for your reply! I appreciate the info. That's what I thought.
Old 05-07-2019, 08:28 PM   #5
BRZ Guy
Drives: 2018 BRZ
I’m reviving this post as I have a question on the EVOlution that’s similar.
So I currently have the EVO 3” exhaust and it’s flange connects to my OEM front pipe with Greddys provided bolts and flat gasket, doing away with the donut (as per Greddy’s instructions).
I’m about to order a JDL 3” Over pipe / Front pipe combo and have no clue on what flange I need to connect to the EVOlution flange.
JDL’s rear flange choices are:
3.0 flat flange
2.5 flat flange
2.5 OEM donut style
Please help, I’m getting different answers.
BRZ Guy is offline   Reply With Quote
Old 05-07-2019, 08:53 PM   #6
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
So I currently have the EVO 3” exhaust and it’s flange connects to my OEM front pipe with Greddys provide bolts and flat gasket, doing away with the donut (as per Greddy’s instructions).
3.0 flat flange
2.5 flat flange
2.5 OEM donut style
If the Evo3 flange is flat, get a flat flange. If the Evo3 is a 2.5" exhaust, get the 2.5" option. If it's a 3" exhaust, get the 3" option. If it's not OEM catback, you do not get the 2.5" OEM flange.
Old 05-07-2019, 09:21 PM   #7
BRZ Guy
Drives: 2018 BRZ
I’m getting JDL’s 3” exhaust and thought about selecting their 3” flange.
I’m just unsure on the EVO’s flange size with it bolting up to the OEM sized flange. I want to install this without error.
I’ll call Greddy and ask.
Old 08-25-2019, 07:05 PM   #8
Glitchy86
Drives: Red 86
Please I need your help. I really like the sound of the Greddy evo gt but I'm very concerned about it hanging low. I have 17×9 +38 wheels and 245/40 tiers and will lower my car 1".
Do you know if I will be scraping like crazy everywhere I go or is it gonna be very minimum scraping?
Thanks.
Sent from my SM-G975F using Tapatalk
Glitchy86 is offline   Reply With Quote
Old 08-25-2019, 11:37 PM   #9
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
Thanks.
From what I’ve read, 1” should be fine and anything lower than that would start to scrape. Of course it depends on how the roads are where you live. I considered it for a while and it looks badass, but the roads here are shitty
Will BRZ is offline   Reply With Quote
The Following User Says Thank You to Will BRZ For This Useful Post:
Glitchy86 (08-27-2019)
Old 08-27-2019, 05:48 AM   #10
Glitchy86
Drives: Red 86
That's what I'm concerned about as we have some shitty roads here as well. But I like the sound of it the most.
Thanks for your help again man.
Old 08-27-2019, 11:59 AM   #11
norcalpb
norcalpb's Avatar
Thanks.
You’ll only scrape if you gave people in the back seats and hit a big bump.
Then you can say goodbye to your greddy resonator as it it’ll spider web crack into completely invisible leaks that you’ll never be able to fix without replacing the resonator.
Old 08-27-2019, 12:25 PM   #12
Glitchy86
Drives: Red 86
I use my back seats as a storage place. Never knew ppl can fit in the back lol.
So as long as I don't have people in the back I'll good?
Old 08-27-2019, 06:33 PM   #13
norcalpb
norcalpb's Avatar
Correct, but just be mindful that your exhaust will prob be the first thing that touches if the undercarriage gets close to the ground.
Old 08-27-2019, 09:43 PM   #14
Glitchy86
Drives: Red 86
Man I'm still not sure if I should take the rest and deal with it coz I like the sound and the look of it or I should look for other safe options.
FS : NEW GREDDY Evolution GT Exhaust itwillboost Engine, Exhaust, Bolt-Ons 3 08-05-2016 04:14 PM
GReddy Evolution GT ShadowReaper Engine, Exhaust, Transmission 37 03-01-2016 11:00 PM
FS: Slightly used Greddy Evolution GT CBE blueap2 Engine, Exhaust, Bolt-Ons 9 01-26-2016 11:24 PM
Thoughts on the Greddy Evolution GT.. WhenzLunch BRZ First-Gen (2012+) — General Topics 5 03-13-2015 03:32 PM
