Drives: 2014 Scion FR-S Monogram (Whiteout)
Changing fluids for the first time
Hey guys,
I wanna change my car's fluids myself for the first time. I plan on going with Motul but I don't know exactly what I need. I haven't changed fluids in the 18 months that I've owned the car beyond what they've done at Service and it's at around 14,000 miles. Could anyone tell me which Motul to use for which fluid change and how much I'd need to buy if I want to drain the fluids and replace it completely? Thanks! |
#2 | |
Killed Scion
Drives: 2013 FR-S Whiteout
Engine oil? Trans fluid? Diff fluid? Brake/master cylinder fluid?
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
MT or AT ..... ??
humfrz PS - I believe your owners manual will give you the information on fluid capacities (p. 340+). ![]() humfrz |
MT and I planned to do Engine, Differential, and Transmission. Unless you guys think it's a good idea to do break fluid as well?
Killed Scion
do the brake fluid just to better performing fluid. Might as well do SS brake lines and pads as well while ur at it.
So which Motul products will I need to change the fluids on those?
Inactive
Drives: .
Gear300 for the diff and trans and just pick your favorite for the engine, you need about 4qts to do the trans and diff.
[insert cool phrase here]
Drives: BRZ Premium
Search. Use it, love it, die by it.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
Drives: 2015 BRZ, 2005 STI, 2024 Type R
Check out the DIY section of the forum for all the procedures and recommendations.
#10 |
Custom User Title
Drives: Asphalt FR-S MT
SS brake lines are pretty pointless.
Otherwise, I use Amsoil. Any good oil will work fine though.
| First time changing oil | Jonathanlim | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 16 | 01-23-2016 04:38 PM |
| Motul fluids | Filipino Royale | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 88 | 04-20-2014 09:36 PM |
| Mixing Transmission Fluids? | l0aded | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 8 | 06-27-2013 01:45 PM |
| How often are you changing fluids? | smbstyle | Tracking / Autocross / HPDE / Drifting | 2 | 06-07-2013 10:56 AM |
| When to replace the following fluids in the BRZ? | chenshuo | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 12 | 05-12-2013 12:17 PM |
