Old 02-28-2016, 07:06 PM   #1
Cooperdh
Hot Lava Lover
Cooperdh's Avatar
Drives: 2013 Scion FR-S- lava
Mach- V Awesome wheels
I just put these on my car today. They are 17x9 with 42 offset. The tires are 255/40. I am on Tanabe racing springs with about a 1 inch drop. Before I got them, I tried to do as much research as I could because I was afraid they would rub. After install, I turned the front wheel as far as it would go and it very lightly rubs on a small part of the rear plastic cover. Nothing really to worry about at this point. Has anyone else had much experience with these wheels and tires this meaty?
Cooperdh is offline   Reply With Quote
Old 03-01-2016, 11:47 PM   #2
ailikesiliu
Drives: はちろく
they look super light, how much do these weigh?
ailikesiliu is offline   Reply With Quote
Old 03-01-2016, 11:53 PM   #3
Cooperdh
Hot Lava Lover
Cooperdh's Avatar
They are light. They come in at 17.8 pounds a wheel. For a 17x9 wheel that is pretty good.
Old 03-02-2016, 12:14 AM   #4
ailikesiliu
Drives: はちろく
Great! Thanks for the info.
Old 03-02-2016, 12:31 AM   #5
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
5mm spacer and call it day to avoid rub. It's because your offset makes it sit in further. Had no issues with my 255/40s on 17x9+35s w/ lowering.
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 03-02-2016, 01:37 AM   #6
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
You running any camber?
tigermack is offline   Reply With Quote
Old 03-02-2016, 03:50 PM   #7
Cooperdh
Hot Lava Lover
Cooperdh's Avatar
Me? No camber.
Old 03-02-2016, 11:04 PM   #8
umpadupa
umpadupa's Avatar
Drives: 94 civic hatch, Whiteout frs
I'm running the exact same set up. 255 40 17 Federal RSR daily. No problems at all. I'm dropped about 1.5 i have no wheel gap, when dropping the natural rear negative camber takes care of my rear rubbing. I see you got a tune from bob too!
umpadupa is offline   Reply With Quote
Old 03-16-2016, 02:43 AM   #9
Davesta619
Drives: Brz
Im on the fence on these wheels myself. Only thing stopping me from buying them is the front clearance. I'm on eibach pro kit and afraid of the rub. Anyone know if all I need is the 5mm spacer upfront and that would solve my worries?
Davesta619 is offline   Reply With Quote
Old 03-16-2016, 11:30 AM   #10
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Run 245/40 instead.
Originally Posted by humfrz
I'm old and lazy
Old 03-17-2016, 01:32 AM   #11
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
Depends on the tire i think. If you're running a 255/40 in a ZII/RS3/RE11/RE71/Rivall or similar, you will probably rub.
Now if you're opting for a slimmer "255", then you can squeeze by..
But the moment you want to introduce any kind of additional camber via bolts, you'll be SOL.
I kinda fucked up and thought I could squeeze by with NT01s and bolts. After measuring, it really wasn't going to happen. I have Velox camber plates on order, and the camber bolts I have will be used to add any positive camber to get everything to fit.
Get 245/40 If you don't want a headache... Unless you need it for hpde, theres no real benefit to stuffing a 255 on there anyways.
Joe-G is offline   Reply With Quote
Old 03-17-2016, 01:35 AM   #12
umpadupa
umpadupa's Avatar
Originally Posted by Joe-G View Post
Are you on coilovers?
If not, and you're on springs... are you running any camber bolts?
Just coilovers, i dont even have rear LCA, just the natural camber from the drop clears everything on my car. just took it to alignment and its it.
No rub or anything in the back. the front i have top hats so those are just cambered enough to clear and for street driving atm.
Old 03-17-2016, 11:01 AM   #13
Cooperdh
Hot Lava Lover
Cooperdh's Avatar
Clearance
Yeah I agree with the others. I got lucky with the tires I have and them not rubbing. I happened to buy these wheels with the tires already on them. I inspected the tires and noticed the edges were less aggressive than other tires so I gave them a try. If it were any other tires, they would have rubbed. Save yourself some worry and get 245/40's.
Old 03-18-2016, 08:37 AM   #14
Timmy_Jones
Spun
Drives: 23' Supra
Wheels and paint go together great.
I am relieved you have all those stickers, I wasn't sure where you lived or what kind of parts you have on your car; now I know.
Timmy_Jones is offline   Reply With Quote
Mach V Awesome wheels Mach V Dan Wheels and Tires 187 11-18-2022 09:18 AM
WTB: Mach V Awesome 17x9 Wheels k.houan Want-To-Buy Requests 2 12-23-2015 11:08 PM
Mach V Awesome Wheels (17x9 +42, 5x100/114) Gunmetal smbstyle Wheels and Tires 3 11-06-2014 05:07 PM
(WA) Mach V Motorsports - Wicked Awesome [Racing Wheels] - Gunmetal 18x9.5 $999 nicholaswj Wheels and Tires 6 06-23-2014 04:12 PM
WTB Mach V Awesome 17x9 +42 wheels ATL BRZ Want-To-Buy Requests 1 01-19-2014 11:10 PM
