Old 02-22-2016, 05:04 PM   #1
Wolfkiller
Drives: Whiteout FR-S
Getting a new transmission. New Clutch? Flywheel?
The dealer is giving me a new transmission and my friend that works there says they will install a new clutch on the car for free since the tranny is already out, I just need to buy the parts.
I only have 40 thousand miles on the clutch and always rev match for smooth shifts so I'm sure my old clutch is still good.
Any reason to go aftermarket? I could get a lighter flywheel but I'm completely stock, no turbo, nothing.
I can go stock clutch kit and have a brand new clutch installed for free since they're doing the transmission anyway. I'd just pay for the clutch parts.
Or, I can just leave it alone and wait for the clutch to go bad, probably sometime after 100k miles.
Thoughts?
Thanks guys
Wolfkiller is offline   Reply With Quote
Old 02-22-2016, 05:11 PM   #2
With the spotty history on the throw out bearings on these cars I would at least get that done. If the rest is good just leave it.
Old 02-22-2016, 05:14 PM   #3
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
Definitely get the TOB changed, I'd suggest you try the ACT heavy duty one they make for our cars, haven't done so myself but they can't be worst than the oem one
fumanchu1 is offline   Reply With Quote
Old 02-22-2016, 05:47 PM   #4
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
I would recommend getting the Exedy stage 1 kit.
Muaddib is offline   Reply With Quote
Old 02-22-2016, 06:33 PM   #5
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Exedy does make an "oem" clutch for our cars.
MS, CSCS, TSAC-F, CPT
Old 02-22-2016, 08:28 PM   #6
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Lighter weight with less MOI flywheel is more useful on a stock motor than a heavily modified/turbo one...it will give you better engine/throttle response and make the car more tossible/precisely controllably. There is a OEM TRD (Japan) lightweight flywheel - 40% lighter than stock with a much lower MOI due to having mass removed from the outermost region near the gear ring, like the Toda one.
https://www.japanparts.com/parts/detail/42820
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 02-22-2016, 08:50 PM   #7
86kahl
86kahl's Avatar
Drives: whiteout, dark tint
I'd second the recommendation on the Exedy stage 1. Pedal feels like stock with a lot more bite/clamping force. Plus the kit comes with a better TOB.
At 60k my clutch disc looked fine but the TOB seized up and I didn't wanna drop the transmission twice by chancing it with the stock clutch. I'd take advantage of not paying labor on dropping the trans and throw either the Exedy stg1 or ACT streetlite 👍🏽👍🏽👍🏽👍🏽 trust you won't regret it
86kahl is offline   Reply With Quote
Old 02-23-2016, 12:13 AM   #8
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
if you're interested in going turbo/super later this would be a great time to get a clutch with plenty of buffer room in there. Even the stiffer pressure plates aren't that bad in these cars.
Gear_One_Performance is offline   Reply With Quote
OEM Clutch And Flywheel with 14k. nickmerronesucks Transmission and Driveline 15 10-22-2015 04:57 PM
Competition Clutch Stage 3 clutch and flywheel, who has one and what do you think? OICU812 Engine, Exhaust, Transmission 2 05-17-2014 01:56 AM
6 MT Swap, Complete: Transmission,Starter, Flywheel, Clutch, Driveshaft, Pedals, Hydr ecda Transmission and Driveline 2 01-30-2014 10:45 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
