Quarter Tank Racer
Drives: Currently Carless
Finally drove an FR-S. I think I understand now.
Hey guys, new member. Possibly staying for a while, depends on what I buy to replace my MK1 ZX3 (rip).
I've been driving a few cars around my price range (15-20k or so), but until yesterday I hadn't driven an FR-S. My car guy friends, for the most part, bitched that it was "too slow," that it'd be unusable. But I spent the last few years in something damn slow without any problems, so I really don't see what they're on about. Straight line, stock? Yeah, I wouldn't say the FR-S feels quick, but it's enough. Anyway, more to my point -- the overall experience, though short (because dealership) was very positive. I never did like the way the FR-S looks in photos, but it's striking in person, in the right color. What I did notice as I got in -- the FR-S feels like an early 2000s Toyota on the inside. All the switches and placements felt super logical, and even on my short trip I didn't hunt for anything. It's a very simple place to be, which is a rarity these days, where even cheap cars are getting annoying levels of tech. The clutch throw is SHORT, but so familiar. I didn't think modern cars had clutch throws this short (my Focus had a very similar throw, though the feel was better. Hydraulic system though). The bite point was a little blurry, but much better than most of what I've driven. Steering, on the other hand -- granted, I only had a short time with it, but the electronic steering is pretty nuts for such a cheap car. It felt about as heavy as modern Fords in their "track" setting, but it's a bit better defined. My big question is the gearbox, however. I'm used to longer throws (yay Ford gearboxes) but the stock shifter on the FR-S was nice...until I tried quicker shifts. Third gear was just not having it. It may have been slightly cold still, but is that normal for these cars? I'm not sure WHEN exactly I'll be ready to buy yet, but I do like the FR-S quite a bit. Felt like a RWD version of the last Celica. It's infinitely better to drive than the GTI, easier to handle than the FoST (GG open diff, Ford), and I actually fit in it really well (sadly, the FiST is claustrophobic). And the WRX hatch is just stupid overpriced. |
I haven't had issues with 3rd gear.
You will get used to the gear box. It is very notchy and the "close enough" technique used in many cars just won't cut it. I actually really prefer the shift on these over many I have had in the past.
Did you drive a used car?
Drives: 2013 FR-S Base, 1997 Jeep Wrangler
You can't really jam gears in it. It does improve as the gear oil warms. You can also replace the transmission fluid with a better fluid such as Amsoil. Clutch feel is greatly improved after the removal of the assist spring on the pedal. I've owned mine for 6 months now and don't feel overwhelming desire for more power.
Well hello, Malibooya, and welcome to ......The Forum .........
![]() Yep, the manual transmission on the FR-S much prefers to be warm before it shifts real smooth. All in all, I've found the FR-S to be a fun car to drive. Lots of things can be done to make them ..... go faster. However, once you get that puppy up state into the hills, you will find out what it likes to do best ........ ![]() humfrz |
#7 | ||
Quarter Tank Racer
Yes. I drove this one specifically. Less than 18K miles.: http://www.cargurus.com/Cars/invento...ting=133529073
You can't really make the gearbox do what it doesn't want to do on this car, it has a narrow goldilocks zone where if you do it right it's fuckin' buttery smooth and it is not like most mass produced gearboxes that are designed for everyone from the teenager to the cheap pencil pusher to your granny. I don't think I was nailing it consistently until I was 30k miles and two years into owning the car.
imo if you're driving around town, sub 4k rpm you simply can't rush the gearbox, at all. If you're banging shifts off the redline at +7k rpm when everything is up to temperature it'll shift as fast as your hands and feet can move with just enough resistance so you know you're flogging it but not so much it's resisting your advances. Good luck, and an important step along life is figuring out that when it comes to many things, your buddies opinions and the opinions of internet strangers aren't terribly important, you only need to make one person happy. ![]() Edit: Weird thing about the car, I don't think it'll apply in many other cars but I almost always double clutch when I downshift around town, it eliminates the resistance in the lever as I go to 3 or 2. But when I'm at the track hard on the brakes at 5k rpm the heel-toe blip allows it to slide right in. Every car has a different rhythm needed to operate it harmoniously and that rhythm changes whether your cruising or thrashing or somewhere in the middle. |
#9 | |
Quarter Tank Racer
The FR-S seemed fine low-down and towards the mid-range, but it didn't really have much to say past 5k RPM. |
#10 |
Drives: GT86
3rd gear is nice enough.
2nd is the bad one. |
#11 |
#12 | |
#13 |
Newbie
Drives: Gt86
Its a great car to drive, if you like celicas then you'll like this even more, with the manual gear you need to let the car warm up a bit, until it does you just need to rev it a bit in between changing gears ( if you're on first and going to second rev when you're in neutral and same if you're downshifting ) Once the gear oil is warm enough its as smooth as silk
This car makes driving from A to B a much more interesting experience, and yeah the gear takes a bit of getting used to but once you get the hang of it you'll be fine |
#14 |
Drives: 2016 Scion FR-S
My transmission goes into 3rd gear super slick, 2nd is a bit notchy. This car is all about handling – it’s very good. It may not be the fastest in a straight line, but a good driver that can make the most out the handling can often times out run someone who can only push the gas petal down.
Of course, I’m only talking sanctioned events like autox…. |
| I finally understand what everyone on this site means now! | SUB-FT86 | Scion FR-S / Toyota 86 GT86 General Forum | 52 | 06-28-2013 01:36 AM |
| I Think I Finally Understand How People Crash | 636 | Scion FR-S / Toyota 86 GT86 General Forum | 103 | 05-27-2013 11:36 PM |
| Finally got to see an FR-S in real life...almost drove it too... | Rawhyde | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 08-10-2012 01:46 PM |
| Finally test drove the FR-S | cleethree | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 06-14-2012 01:35 AM |
| Finally drove an FR-S | Shin | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 06-10-2012 07:20 AM |
