Old 02-12-2016, 10:12 AM   #1
oldlostcory
oldlostcory's Avatar
Drives: 2013 WRB BRZ Limited
Advice on brakes for a trip to Tail of the Dragon.
I have done a little research but was hoping some of you guys can give me some advice. I am heading down to the dragon for my first time. We are going to be down there for a week, so a lot of drives I imagine. I'm close to needing new pads/rotors anyway and I've heard under hard driving OEM can fade pretty fast. What would you guys recommend for this? The rest of my driving the stock pads are fine. Should I just replace with new OEM? Go with Winmax W1? Also just blank rotors? Replace the stock brake fluid? I know I am probably over thinking this.
oldlostcory is offline   Reply With Quote
Old 02-12-2016, 10:27 AM   #2
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
lol...bring snow tires. its coming down again. tdot salts their side.
its a 2-3 kinda road. you might hit the red line in 3rd after parsons branch going towards deals gap but watch for the dip in that lane....do stay in your lane.
the skyway is where your brakes will glow.
thomasmryan is offline   Reply With Quote
The Following User Says Thank You to thomasmryan For This Useful Post:
oldlostcory (02-12-2016)
Old 02-12-2016, 10:49 AM   #3
oldlostcory
Should have mentioned we are not heading down till summer. Yeah I plan to stay within my abilities and definitely not crossing center line. Are you running stock pads/fluid? The guys i'm going with plan to drive skyway.
Old 02-12-2016, 11:40 AM   #4
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
If you're going to hit it hard, at the very least, upgrade fluid. You might want to upgrade pads to something more aggressive too but that's up to you, OEM should be fine for some spirited driving.
Lynxis is offline   Reply With Quote
The Following User Says Thank You to Lynxis For This Useful Post:
Old 02-12-2016, 12:02 PM   #5
phm14
Loves the Smell of Track
phm14's Avatar
Drives: '13 86
Stock pads and rotors should be fine. In my 39 years of driving, I've only needed a pad upgrade on track days. Flushing your brake system every 2 years or so is always a good idea. I like ATE fluid. If you can still find the blue (US fed regs kind of banned it), alternating flushes with the gold makes it easy to see when you have a complete flush. Carbotec pads are my favorite for the track, but they can be noisy on the street, and they were $350.00 a set last i checked.
http://www.autohausaz.com/search/pro...4haBoCIfjw_wcB
2020 86 Hakone MT build thread: https://www.ft86club.com/forums/show...31#post3326231
2013 Toyobaru 86/FR-S 6MT, Red, aka Candy O SOLD
http://www.ft86club.com/forums/showthread.php?t=7934
phm14 is offline   Reply With Quote
The Following User Says Thank You to phm14 For This Useful Post:
Old 02-12-2016, 12:33 PM   #6
thomasmryan
Drives: hyper blue
Fresh fluid is always a good idea. My car is new (<2k) so utterly stock.
Lots of fun roads in the area. I usually play nocturnally but I did take a slow cruise there last month.
Old 02-12-2016, 12:44 PM   #7
oldlostcory
Thanks for the replies guys, I'm going to stick with stock pads I think and just change the fluid. Car will be 3 years old (35k miles) in June, new fluid isn't a bad idea.
Old 02-12-2016, 12:48 PM   #8
wparsons
wparsons's Avatar
Changing the fluid on stock pads is a waste IMO (unless you're flushing with OEM fluid). You'll get pad fade long before you boil the fluid with stock pads.
I would get a good hybrid pad (Project mU HC800, Ferodo DS2500, etc) and upgraded fluid. It'll be better on the street, and definitely not fade for this trip.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
CSG Mike (02-12-2016), Hyper4mance2k (02-12-2016)
Old 02-12-2016, 12:57 PM   #9
thomasmryan
Drives: hyper blue
The park opens some other cool roads after April 1st. Shoot me a PM before you come down.
ATE 200 is the blue equivalent but fresh anything dot 4 is good.
Old 02-12-2016, 01:15 PM   #10
phm14
phm14's Avatar
Drives: '13 86
The reason you want to change brake fluid every 2-3 years is because brake fluid is hydrophilic, that is, it attracts water. The longer it stays in your car, the more water it absorbs. Water turns to steam at 212 degrees F, and that can cause you to lose your brakes under extreme use temps. Water can also cause corrosion in the brake system and cause premature failure/wear of seals etc. Pad compounds are selected to match operating temperature range for a given application.
Old 02-12-2016, 01:41 PM   #11
Lynxis
Lynxis's Avatar
Coming from someone who has run RBF600 with OEM pads on track, I don't really agree with you that the pads are the problem. They did start to fade after around 20 minutes on track but it wasn't severe and never got worse than a certain point. They should hold up to some spirited street driving.
I'm not saying it isn't a good idea to upgrade them anyway because the OEM pads DID fade and it's good to run a more aggressive pad for more aggressive driving but I don't think it's required.
Old 02-12-2016, 02:06 PM   #12
CSG David
CSG David's Avatar
Using stock equipment is fine.
If you intend to change your fluid for street use, Motul RBF600 (or any standard DOT4) will work. If you start autocrossing competitively, then looking into a higher quality DOT 4 is warranted.
If you are looking for some pad upgrades, Winmax W3, Ferodo DS2500, and Project Mu B-Force (or HC+800) are excellent upgrade options. We do carry these products as well. If you want something a little less aggressive, we also have our own CSG street pads that are meant to cover the uprated street activity.
The Following 4 Users Say Thank You to CSG David For This Useful Post:
Jmonty (02-21-2016), Lynxis (02-12-2016), oldlostcory (02-12-2016), wparsons (02-14-2016)
Old 02-19-2016, 09:50 PM   #13
Lateral G
Drives: 2017 Series.Yellow + Perf Package
I run the dragon 15 times a year as I live very close. I cooked OEM pads there after many runs. Usually feel pad fade in the last third of the run. I would upgrade fluid and pads or you might run into problems that force you to back off and cool things down.
Lateral G is offline   Reply With Quote
The Following User Says Thank You to Lateral G For This Useful Post:
Lynxis (02-20-2016)
Tail of the Dragon Trip kanundrum FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 26 05-27-2014 12:40 AM
Road Trip! Pike's Peak to Tail of the Dragon VTwinSuzuki BRZ First-Gen (2012+) — General Topics 2 03-27-2013 09:11 AM
Tail of the Dragon Run Mar 22-24 jstans84 NY / NJ / CT / PA 3 02-08-2013 12:34 AM
Tail of the Dragon? Craig NY / NJ / CT / PA 21 12-26-2012 05:02 PM
Tail of the Dragon Tomcat9700 Scion FR-S / Toyota 86 GT86 General Forum 32 02-10-2012 02:30 PM
