Old 02-09-2016, 10:01 AM   #1
ka-t_240
Aftermarket Seats
Hey everyone - looking at buying aftermarket seat for track days as I am likely buying a HANS/etc this spring. I am looking for something to help lower me in the car as my helmet will scrape the headliner with the OEM seats. What setup are you running, did it lower you in the car? I am 6'1" and about 225lbs so need to find a seat that fits me, and the car. Need to work on the last part, but most of us will say that.
Post up your setup, pics, and what you are using for brackets!
ka-t_240 is offline   Reply With Quote
Old 02-09-2016, 10:23 AM   #2
-Phil
Drives: Rb25 neo brz
You can go with a Corbeau FX1 Wide setup ( I am 6'6" 250) if you're looking to save some money or you can go as far as a Sparco ergo or an EVO 3
-Phil is offline   Reply With Quote
Old 02-09-2016, 11:20 AM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Virtually any bucket seat will lower your head relative to the headliner if the seat rails are side mount.
-alex
Old 02-09-2016, 03:29 PM   #4
aciddemon
Drives: 2013 FRS
If you can, go sit in a bunch of them to see what what you like best. I was looking at either a Racetech or Recaro Pro Hans but ended up with an OMP HTE-R as it was by far the most comfortable and best fitting for me. The wide Recaro was a bit to big but the normal was painfully tight.
Good luck.
aciddemon is offline   Reply With Quote
Old 02-09-2016, 06:35 PM   #5
ka-t_240
Good luck.
I really wish I could find somewhere to sit in all of these options. It is tough to buy a seat with never sitting in one. I live in the middle of nowhere, I think I might know about 10 people in reasonable driving distances with quality seats to try out.
Got any pics of the OMP, they are so comfy!
Old 02-09-2016, 06:36 PM   #6
ka-t_240
-alex
My biggest concern is finding a seat that fits me, that also fits the car. I know it can be hard to fit "wides" in some chassis.
Old 02-09-2016, 06:41 PM   #7
Blizzard
Drives: '13 FR-S Whiteout
I went with the Sparco Pro 2000 II which is a fairly wide seat. I really like it. Keep in mind you will not retain the use of factory seat belts with a lot of seats. So, you need to consider a roll bar/cage with a bar for the harness. You can get just the harness bar but you risk your safety in a roll over (stock seat belts allow your torso to bend to the side, your harness will not). Some people think bolting in a race seat is a simple affair, but a lot of times it involves adding a roll cage, and harness.
Blizzard is offline   Reply With Quote
Old 02-09-2016, 07:10 PM   #8
byun
byun's Avatar
Drives: 2015 BRZ CWP
I have the Cobra Suzuka Pro GT which is pretty wide and fits the car perfectly.
byun is offline   Reply With Quote
Old 02-09-2016, 09:38 PM   #9
ka-t_240
What size are you? That looks like a decent seat. Any pics of your setup?
Yes, the rest of that is all implied, looking to start using a hans device, need to get the full setup figured out. The seat is the key thing IMO, the rest is "easy".
Old 02-10-2016, 10:44 AM   #10
Blizzard
I am 5' 11" and about 200 lbs. There is some wiggle room in the seat, but I use the removable bolsters to adjust the fit. I don't have any pics on hand. I could probably snap a few soon. If at all possible, I would give the same advice as previous posts and sit in as many as you can. I went to a local store (RallySport Direct) and sat in quite a few before I pulled the trigger on the Sparco.
Old 02-10-2016, 02:04 PM   #11
ka-t_240
Ya, we have no shops locally that would ever consider stocking seats. Even in the Minneapolis area. There is one guy, but he only has 2 OMP seats. Just have to find seats in cars somerwhere. The joys of the Midwest!
Old 02-10-2016, 07:04 PM   #12
enivid
enivid's Avatar
Drives: WRB JR BRZED
^^^ I sat in his seat. You need a pit crew to help you get back out.
enivid is offline   Reply With Quote
Old 02-11-2016, 12:24 AM   #13
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
I'm 6'2" and about 225 as well. I have the Sparco Ergo Large and if it was any bigger, it wouldn't fit in the car. The seat fits me perfectly though. I have side mounts with sliders. If you can get away with not using sliders it will put you almost an inch lower in the car.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 02-11-2016, 12:55 AM   #14
zdr93523
zdr93523's Avatar
Sparco Ergo Large, Planted base, Sparco slider, Sparco side mounts with seat on the 2nd holes from the bottom which is the lowest you can mount the seat with a slider.
Ignore the mess in the pics... the car is undergoing some pre-season changes.
www.makesmodels.com
www.camautomag.com
Please post your Aftermarket Seats Scooby South Cosmetic Modification (Interior/Exterior/Lighting) 184 10-29-2018 11:29 AM
shop that stocks aftermarket seats? serial gixxer Northern California 9 06-02-2015 03:51 PM
Where To Test Aftermarket Seats itsibarra Southern California 5 03-31-2015 12:07 AM
DFW Area Aftermarket Seats to Sit in? nivek111070 Southwest 4 03-17-2015 11:46 AM
Aftermarket Seats sets off SRS light? Hanakuso Cosmetic Modification (Interior/Exterior/Lighting) 1 08-25-2012 05:09 PM
