Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Members Classifieds > Want-To-Buy Requests
Old 02-04-2016, 12:16 PM   #1
3D1
Drives: Scion FRS
WTB: D3PE Turbo Kit
Currently deployed. Looking to buy a D3PE Turbo kit so I can have a project when I get home. D3PE no longer sells this kit. I know some one in Nov of 15 was selling the same kit and I missed that opportunity.
3D1 is offline   Reply With Quote
Old 02-05-2016, 11:53 AM   #2
els7x5
Drives: Black FR-S
I think I bought the kit you're talking about. It's a good setup, if you have any questions when you get one feel free to pm me.
els7x5 is offline   Reply With Quote
Old 02-05-2016, 04:38 PM   #3
3D1
Drives: Scion FRS
Did you install it yourself? Also, did you take any pictures? Ive seen it before, but it is always neat to see some one else's set up.
Old 02-05-2016, 06:47 PM   #4
els7x5
Drives: Black FR-S
Took plenty. I'll put them up once I get home. I did the install myself and it was quite simple.
Old 02-10-2016, 03:13 AM   #5
els7x5
Drives: Black FR-S
D3PE Turbo Kit install
Sorry this took so long. Been on 60 hour weeks so not much free time. Free bump though! There is an extreme lack of information about this kit so I am including all the relevant pictures I took during the install. If you need anything at all, minute detail image or whatever, just ask.
The greatest help to me was other turbo guides!!! I cannot stress this enough. The Works Manual and Ptuning Manual helped me figure out so much stuff and even provided a direct guide to the heat shielding I will talk about later. I picked those manuals as they had the same mounting locations for their turbos and that ended up giving an approximate guide to this one since there's no official D3PE install manual. On to the building.
Bought an oil sandwich plate, told the guys this wouldn't work due to the recessed placement of the filter but they insisted and I bought this anyway just to return it a few days later. Ended up just getting a few porting pieces and running it off the oil lines right next to the filter. There's a good amount of info about doing this on here but I don't have any of those pages saved anymore so you'll have to find them.
Tear down and sealing off the intake during installation.
http://imgur.com/8UcWndi
I skip a lot of steps in the pictures. I jacked the car up onto stands so I could be comfortably under it and removed all of the skid plates and then the front pipe. You will need to pull the overpipe off (Hint: Get a jack under the engine block to lift and give the overpipe just enough space to escape without cutting the heat shielding off. The bolts on the shielding of my overpipe were rusted beyond use.) and remove the headers. Either you'll be using aftermarket headers or you'll want to knock the cat out of the factory one so that you don't risk any of the cat breaking and flying into your turbo and destroying it. I didn't know this and had to go in and pull the headers off after the full install. That was the biggest pain of the whole install.
Removed front bumper.
http://imgur.com/HGy3zls
From there I reinstalled the headers and attached the up-pipe from the headers into the engine space so that I could set the turbo on and get an idea of how it would sit as well as what would need shielding/relocating.
http://imgur.com/TIHbt1f
Once that was in place I started to lay out the piping and get a feel for how it would move through the car. I did this a lot and it really helped as far as planning went.
http://imgur.com/n8ejLyc
http://imgur.com/DLdiBPD
http://imgur.com/Y4wUZ95
http://imgur.com/jOZKDUy
Removed the crash bar and the windshield wiper reservoir. The factory one will not fit and I am sure there's options that would fit I haven't bothered with it yet. I find it easier to just keep a bottle and rag with me.
http://imgur.com/Pk5kaLN
The horn and temp gauge will need to be relocated to the side of the radiator which was very simple and required no extra parts.
Unfortunately my intercooler had a bit of the metal snapped off where it should attach to the crash bar but a little drilling and a trip to Lowes later and I had that solved. This intercooler sucks to mount. No other way to put it. Other kits mount to the front or back of the crash bar because there's plenty of spots to do so. I had to use a lot of ratchet extensions and some extreme ingenuity (vice clamps) to put bolts and nuts through the bar and tightened in order to get this thing secured.
http://imgur.com/ojIOcxS
http://imgur.com/gPFhEj6
With that on, run all the pipes and hook it up as if this is the final install except for the actual turbo area. You will need to heat wrap that area a lot. I went through two and a half roles of heat tape at something like 15-20$ a roll and another large single sheet I used to create a sketchy battery wall to shield everything.
http://imgur.com/c5S3YIx
(My homemade heat shield for the battery, works quite well, made of steel and those metal L joints you can see near the windshield in earlier pictures.)
http://imgur.com/s8BjzcN
Everything sealed off you can mount the turbo then mount the downpipe. You cannot mount the DP first or the turbo wont fit. It's a tight squeeze. Mount the dump tube and wastegate if not already done and run those lines to your boost controller. I had some help from a mechanic friend of my girlfriends at this point as this was my first time doing a turbo and running the boost lines had me nervous. This actually led to more problems than help though which I will explain.
Set up the catch can, I let the friend do this for me while I worked on something else on the car and mine is apparently set up wrong and is essentially useless. Also run the oil drain line to the pan or if you're smart you'll have bought one of those ports into the crank case that other kits give you. Much simpler and no need to buy a new pan with a drain port or to modify your existing pan (Blitz sells a new pan with the drain port on it for less than it would have cost to have mine modded.)
Hook up the BOV to your vacuum line and your boost gauge and that's really all there is. Just put the car back together from there.
http://imgur.com/Fy3KW9L
http://imgur.com/hla8bL9
http://imgur.com/C3oYu6x
http://imgur.com/zeTZM5d
The whole install was much simpler than I expected and my only regret was paying that guy to help me. He left seals off of my wastegate and the stuff he did right ended up being very simple. It is an intimidating task though if you've never built a turbo before so I just consider it money spent on piece of mind at the time. Hope this all helps!
Old 02-19-2016, 10:56 PM   #6
3D1
Drives: Scion FRS
els7x5 you are the man!!!!! Thank you very much. I was able to buy a kit off a member on here and it will most likely ship out on Monday. I really appreciate you pushing this knowledge my way! I have put alot of turbo kits together so this will be nothing new. Your guide will help me tons!!!
Old 02-21-2016, 03:57 AM   #7
els7x5
Drives: Black FR-S
Awesome! And good to hear. Another member was asking me about it so I thought it was time. Pm me if you run into any trouble. You'd better post the results too!
Old 02-22-2016, 11:33 PM   #8
3D1
Drives: Scion FRS
It's still going to be a bit before im back stateside but expect a summer project! Ill let you know when it ships and when it arrives, which is always the fun part. Thanks again for your help. Im sure ill have tons of more questions.
d3pe
D3PE Turbo Kit For Sale (Priced to Sell) Synack Engine, Exhaust, Bolt-Ons 31 11-29-2015 01:04 PM
D3PE FRS/BRZ KLR Turbo System ANTI_LAG Forced Induction 187 01-21-2014 03:39 PM
Introducing the D3PE "KLR" turbo system... Evan@D3PE Forced Induction 25 06-15-2013 01:24 PM
Another D3PE KLR Turbo System Done! ANTI_LAG Forced Induction 36 01-08-2013 03:56 PM
