Old 01-29-2016, 11:40 AM   #1
Jeff Gray
VizMark Performance
Jeff Gray's Avatar
Drives: 2014 Scion FR-S Monogram Series 6MT
Traction control not working properly/ malfunction
I have a 2014 FR-S Monogram Series 6MT. Three days ago the car stopped letting me turn the traction control off. When I hold down the track off button for more than 5 sec staying still or moving the only thing that comes on is the track off light but not the other light. This is the same with vsc sport mode. I noticed that last night I was able to activate it until the car was completely warmed up and then while I was driving it just turned itself off and wouldn't turn back on. I was just driving down the road at normal speeds. I tried the peddle dance and the same thing happened, just the track off light and not the other. Any idea guys?????
PS: I know "Traction" is misspelled in the thread title. I don't know how to change it.
Regards,
Jeff Gray
904-566-5505
VizMark Performance
Jeff Gray is offline   Reply With Quote
Old 01-29-2016, 11:56 AM   #2
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Reset battery. May work.
Maybe fuses? Lose wiring?
Packofcrows is offline   Reply With Quote
Old 01-29-2016, 11:56 AM   #3
Jeff Gray
VizMark Performance
Jeff Gray's Avatar
Traction controle not working properly/ malfunction
Regards,
Jeff Gray
904-566-5505
VizMark Performance
Old 01-29-2016, 01:52 PM   #4
Jeff Gray
VizMark Performance
Jeff Gray's Avatar
I was thinking that except it will turn off when the engine isn't fully warmed up
Regards,
Jeff Gray
904-566-5505
VizMark Performance
Old 01-29-2016, 02:07 PM   #5
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
Maybe the dash bulb is just burned out?
justatroll is offline   Reply With Quote
Old 01-29-2016, 02:13 PM   #6
JakeRogue
JakeRogue's Avatar
Drives: 2014 Monogram FR-S
just to be sure we're covering everything, normally the TRAC OFF thing comes back on after like 25-30mph, unless you're totally stopped and hold the button down.
I think you should do as others have instructed, maybe disconnect battery, make sure you do it when car is stopped and in neutral, etc.
JakeRogue is offline   Reply With Quote
Old 01-29-2016, 02:23 PM   #7
Jeff Gray
VizMark Performance
Jeff Gray's Avatar
I have used this quite a bit during autoX and other events. There is no doubt it is acting abnormal and that I know how to properly disengage the system. If I start the car, turn traction control off, and just let it sit there and wait, it will turn itself back on without me doing a thing. Also I have reset the computer (battery disconnect) to see if it would fix itself and it didn't.
Regards,
Jeff Gray
904-566-5505
VizMark Performance
Old 01-29-2016, 02:25 PM   #8
JakeRogue
JakeRogue's Avatar
Yikes, yea then I don't know man
Old 01-29-2016, 05:52 PM   #9
justatroll
justatroll's Avatar
just to be sure we're covering everything, normally the TRAC OFF thing comes back on after like 25-30mph, unless you're totally stopped and hold the button down..
Mine will disable above 40 MPH with a 3 second press of the TRAC button.
Old 01-29-2016, 05:56 PM   #10
JakeRogue
JakeRogue's Avatar
So if you just press the button on the left, then the the light TRAC OFF will come on in your car. It only comes on if you're below like 30mph and then will automatically turn back off if you accelerate faster than like 30mph.
If you press the button on the right (VSC Sport), then the car logo with the squiglies underneath comes on, and the VSC Sport lights comes on.
if you're stopped and HOLD the button on the left, then the TRAC OFF and logo withe squiglies will both come on and now that's all your traction control systems off
that is a terrible way to explain it, but pretty sure i'm accurate. (i don't have pics to help illustrate what's what)
Old 01-29-2016, 06:45 PM   #11
justatroll
justatroll's Avatar
I just did this an hour ago: @40 MPH - Hold the left button, three seconds, BOTH dash lights come on, and do not turn off until you push it again or turn off the car.
Old 01-31-2016, 12:03 PM   #12
DRFT86
DRFT86's Avatar
Drives: 2016 Raven FR-S
Have you "tested" to see if traction control is full off and may be a lighting issue?
Sent from my SM-G900P using Tapatalk
DRFT86 is offline   Reply With Quote
Old 01-31-2016, 12:16 PM   #13
Elliryx
FT86
Elliryx's Avatar
Drives: 2015 FRS Ultramarine
If you turn off it should stay off unless you turn it on yourself pressing the button.
2015 FRS Ultramarine 8/20/15
TRD Exhaust System | Suntek | Opti - Coat | K&N D.I.F
Future mods: Vortech or Fullblown! Need to more then read some more.
Elliryx is offline   Reply With Quote
Old 01-31-2016, 12:27 PM   #14
Dude! You have the same thing in two threads?
http://www.ft86club.com/forums/showthread.php?t=100720
malfunction, traction control
Cruise control malfunction totally Issues | Warranty | Recalls / TSB 20 02-26-2018 09:13 PM
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 01:48 PM
Cruise Control Malfunction Wyattkb Issues | Warranty | Recalls / TSB 6 12-21-2014 04:37 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
