Old 01-28-2016, 06:01 PM   #1
soilent
Drives: 2022 BRZ Premium
Anyone have issues with LEDs on newer BRZs?
I want to convert all of my stock incandescent bulbs to LED, but I've read some horror stories about shorting out a computer when installing the door curtesy lights. I was just wondering if this is still an issue and if people have had problems with LEDs in other locations like trunk, dome, reverse lights, etc. Thanks.
soilent is offline   Reply With Quote
Old 01-28-2016, 06:03 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Take each story with a grain of salt as no one posts how their LED's are working fine. Get quality stuff (example @Diode Dynamics) and you should be fine. I have an LED dome light and LED switchbacks for about 3 years 0 issues
The Following 3 Users Say Thank You to go_a_way1 For This Useful Post:
Diode Dynamics (01-29-2016), FRSBRZGT86FAN (01-28-2016), Joyride86 (01-28-2016)
Old 01-28-2016, 06:21 PM   #3
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Unplug the battery when you're installing the lights. You can't short anything if it's not wired for power.
jawn is offline   Reply With Quote
The Following User Says Thank You to jawn For This Useful Post:
go_a_way1 (01-28-2016)
Old 01-28-2016, 06:21 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
^ that 2, and don't install them in the rain during a thunderstorm
Old 01-28-2016, 06:27 PM   #5
jawn
jawn's Avatar
It's easy to short the courtesy lights since the bulb is held in place by two conductive arms, and you have to pry the courtesy lights off with a panel tool (or a very conductive screwdriver).
Old 01-28-2016, 07:01 PM   #6
Joyride86
Joyride86's Avatar
Drives: 15 FR-S Firestorm MT
I have every single light replaced with LEDs and haven't had any problems at all. Gives it very clean and modern look.
I am one of those guys that hasn't had a problem that doesn't post about it. Nevermind...I posted about it now.
Diode Dynamics Tail as Turn, LEDs, HIDs | Yospeed Custom Plaque and Frame | Suntek Carbon Tint | Spyder Smoked Side Markers | GrimmSpeed License Plate Relocator and Hood Struts | Five:AD Spoiler | JDM Armrest | Beat-Sonic Backup Cam | Moddiction Anvil 2 | Invidia N2 |
Joyride86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Joyride86 For This Useful Post:
Tcoat (01-28-2016), Tectoniic (01-29-2016)
Old 01-28-2016, 07:42 PM   #7
JohnBgon
JohnBgon's Avatar
Drives: 2016 BRZ Lim. DGM MT
I had my car garaged for almost two weeks waiting for it to be clear bra'd. During that time, I replaced all the interior bulbs with LEDS. I had 5 spare 194's from my previous car. (courtesy lights, trunk, license plate)
No issues so far. I removed the courtesy light and dome housings when installing the LED bulbs. I did not disconnect the battery.
Some crappy phone pics I took for basic comparison:
JohnBgon is offline   Reply With Quote
Old 01-28-2016, 08:26 PM   #8
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
One of my door courtesy lights is 'stuck' on because I accidentally shorted out the connectors when changing bulbs. Because of this, I removed the bulbs from both sides because my OCD will not allow me to have one and not the other. The fix requires that you replace a pricey module that I was not willing to do. I thought about re-wiring the lights using relays and such, but thats a project for a rainy day. So to answer your question, yes this can happen, but if you are careful it can work fine. I would disconnect your battery or the courtesy light fuse before replacing the bulbs.
For the license plate LED, I highly recommend these. I went through a few sets of wedge bulbs and eventually came across these and love them. This is the same seller I purchased from: http://www.ebay.com/itm/Subaru-BRZ-I...item23398ffad1
(dont mind the mess)
Old 01-28-2016, 08:29 PM   #9
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
The issue he's speaking of is the rare BCM/ BIU failure:
http://www.ft86club.com/forums/showthread.php?p=1761758
None of the 2015s have had this issue, also it occurred with lower quality LED conversions or improper installs, @Diode Dynamics have there LEDs that have no wrong polarity so it's very hard to short out. Also if your super worried unplug the battery.
Old 01-28-2016, 08:35 PM   #10
B-R-Z
B-R-Z's Avatar
None of the 2015s have had this issue, also it occurred with lower quality LED conversions, @Diode Dynamics have there LEDs that have no wrong polarity so it's very hard to short out. Also if your super worried unplug the battery.
In my case, and others I've read, it was from accidental contact between +/- on the metal casing that holds the bulb. IIRC, I was using a flat head to bend it back into shape and accidentally shorted. I realized days later that the bulb was stuck on all the time. It fortunately never killed my battery since they are such low wattage. This is why I emphasize careful install and you will likely be ok. A quality of bulb is an extra precaution.
Old 01-28-2016, 09:34 PM   #11
Euro7R
Drives: 2013 Subaru BRZ
My driver side door light is out and passenger side works. I might just take passenger door out to make mines no lights, like FRS lol. Shorted the BIU. Oh well, stuff happens.
Euro7R is offline   Reply With Quote
Old 01-28-2016, 10:57 PM   #12
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
How come the fuses wouldnt protect the other electronics from a short?
But all of my interior lights, trunk light, door lights, and license plate lights are LEDs. No issues here. All from @Diode Dynamics
PandaSPUR is offline   Reply With Quote
Old 01-28-2016, 11:04 PM   #13
B-R-Z
B-R-Z's Avatar
I wonder the same. Poor design on toyobaru on this one.
Again, I think it's the install process that causes the issue, not brand of LEDs.
The Following User Says Thank You to B-R-Z For This Useful Post:
Old 01-29-2016, 08:28 AM   #14
pinski
Stole my avy from zGrinch
pinski's Avatar
Drives: 2015 Audi S3
I've replaced my entire taillights, front blinkers, license plate lights, backup lights and all interior bulbs with LEDs and haven't had a single issue. Bought everything (except the Tom's) from DiodeDynamics and couldn't be more pleased with their quality or customer service.
2015 Audi /S3 | Panther Black | DSG
Gone...2014 BRZ, 2010 Lexus IS F-Sport, 2006 Mazda MX5, 1997 Mustang GT
pinski is offline   Reply With Quote
Rotating tires if one is newer than the rest, how? PandaSPUR Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 23 01-28-2016 08:40 PM
Looking to move to a newer tool box Concorazon Off-Topic Lounge [WARNING: NO POLITICS] 15 11-01-2015 09:53 AM
How to use newer revisions of OFT maps? ie 700I to A01I derka-derka Software Tuning 3 09-05-2015 08:21 AM
eBay Switchback 7443 LEDs fitment issues in turn signal housing dracullus DIY (Do-It-Yourself) Guides 0 08-27-2014 10:28 PM
