Old 01-27-2016, 05:55 AM   #1
JetSpeed
Drives: 06' Forester, 15 '3.6 OBW, 16' BRZ
Sun Visor Warning Labels
Has anyone had any luck covering these annoying labels? I tried to remove the pax side on my Forester with a heatgun and had no luck. Some folks have had luck doing so, although I don't recommend evening trying it.
I know there are some stick-on covers available from eBay etc. however, they look cheesy. My only though is to have them professionally recovered by a shop.
Anyone??
JetSpeed is offline   Reply With Quote
Old 01-27-2016, 07:31 AM   #2
swarb
Heat makes the plastic warp. And it never really completely removes the shadow/imprint left over. Solution is to get it wrapped or find a piece of satin/flat black vinyl to cover it. I have been lazy and haven't gotten to it. I cant decide to cover just the warning label or the whole side of the visor.
Old 01-27-2016, 08:34 AM   #3
firemedic1428
Drives: Pinto
Im just gonna have mine wrapped in Alcantara by JPM Coachworks.
firemedic1428 is offline   Reply With Quote
Old 01-27-2016, 09:52 AM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Anyone??
I sprayed them with plasti dip. The textured part looks the same and the sticker part is a shiny black square hahahaha! Better then yellow but not 100% perfect.
Old 01-27-2016, 12:59 PM   #5
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
I don't know if it works for the BRZ here, but what I did for my Golf R was take a rag, soak it in 90% Isopropyl, and then let it sit on the label for 5-10 minutes, then peeled it off pretty easy. There's a very slight imprint left on it but it's gone otherwise, and no damage to the material.
Luftwaffel is offline   Reply With Quote
The Following User Says Thank You to Luftwaffel For This Useful Post:
~el~jefe~ (04-21-2017)
Old 01-27-2016, 05:09 PM   #6
Rattle
Drives: BRZ soon
I peeled mine off of my current car, the brz's ones might just peel as well.
Rattle is offline   Reply With Quote
Old 01-27-2016, 05:10 PM   #7
DSOmegaX
DSOmegaX's Avatar
as a fellow golf R owner I will try this haha
@dsomegax.cars
Old 01-27-2016, 05:12 PM   #8
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
i just covered mine with patches of carbon-look wrap because that's what i had on hand. you can see them but they're not as obvious as the labels.
shiumai is offline   Reply With Quote
The Following User Says Thank You to shiumai For This Useful Post:
swarb (01-27-2016)
Old 01-28-2016, 12:30 PM   #9
Ashikabi
Ashikabi's Avatar
I tried several things to get them off. Got one off but the area where it was looked very different from the surroundings. Ended up wrapping the whole visor
Old 01-28-2016, 02:18 PM   #10
acetothermus
Drives: Flying in a Blue Dream
Do it yourself or send it off?
acetothermus is offline   Reply With Quote
Old 01-28-2016, 02:29 PM   #11
Ashikabi
Ashikabi's Avatar
I sent it off but I wanted a design on it(so it would match my headliner). I found a diy on google that was very simple. If you don't want something really fancy, anyone should be able to do follow it
Old 01-28-2016, 03:10 PM   #12
acetothermus
I'm most likely going to go the JPM Coachworks route. I like the look of the Alcantara look on the visors.
Old 01-28-2016, 03:14 PM   #13
Ashikabi
Ashikabi's Avatar
Without looking up the piece on the JPM, I can only imagine diy would be cheaper. Should cost about $30 if I remember right
Old 01-28-2016, 03:18 PM   #14
acetothermus
Oh yes, DIY would be MUCH cheaper. But I'd never get the fit and finish that my OCD demands by doing it myself. It's worth it to me to pay more.
Broken Sun Visor feldy Issues | Warranty | Recalls / TSB 99 10-10-2022 10:33 PM
40% Discount on select items! New labels have arrived! Stay Fresh Car Care Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 09-07-2014 05:21 AM
WTS wind visor 115$ okkoem Exterior Parts (Aero, Lighting, Etc.) 0 04-13-2014 01:18 PM
Sun visor warning labels sav AFRICA 57 04-22-2013 06:37 AM
Visor Warning Label Removal poudre Cosmetic Modification (Interior/Exterior/Lighting) 28 09-19-2012 08:16 PM
