Old 01-22-2016, 10:36 PM   #1
mabviper
Drives: WRB BRZ
Lightbulb Custom data logger prototype
I've been working on this project on and off for a while now. I think I have enough to share.
This all started when I saw Toyota showcase their CAN-Gateway ECU for the GT86 platform. I figured that if they can do it, why can't I copy it, lol. I wanted something like the Corvette PDR. A data logger that's seamlessly integrated with the rest of the electronics in the car. While there are tons of data loggers available, I didn't want to install units on the center console or windshield so I started designing my own.
The idea:
1. Interface with canbus to extract data from the car to minimize queries on obdI2.
2. Add in gps, accelerometers and 2 external sensors for oil pressure and something else.
3. Replace oem clock unit with datalogger w/o loosing any of the leds or hazard button.
4. Store data in usb drive.
Right now, my system is able to record the following parameters:
1. Speed
2. RPM
3. Steering angle
4. Throttle
5. Brake pressure
6. Individual wheel speeds
7. Oil temperature
8. Coolant temperature
9. Remaining fuel
10. GPS coordinates @ 25Hz.
11. Lateral G
12. Longitudinal G
13. Yaw Rate
There are other sensors I want to integrate but for now, this is good enough. I'm also saving data to an sdcard instead of usb for now.
But enough talk! On to the video!
[ame]http://www.youtube.com/watch?v=SKlobXXXtIM[/ame]
I also have 2 OLED screens integrated for now. Though, theoretically, you can have as many as you want. I haven't done prototyping the board yet but I've done some analysis on the pinouts of the clock unit. Hopefully by this summer, I can start field testing a prototype unit on local autocross tracks.
For those that want to see how it works on autocross, here are 2 videos I took last year
Field testing at Mosport DDT
[ame="https://www.youtube.com/watch?v=cNekCNSglrw"]DDT SPDA ATTS June 11 - YouTube[/ame]
Field testing at PITL Autocross
Accelerometer data as well as Yaw rate finally incorporated
[ame="https://www.youtube.com/watch?v=fBcDVaWDU_4"]PITL July 2016[/ame]
mabviper is offline   Reply With Quote
Old 01-23-2016, 08:14 AM   #2
D18
D18's Avatar
Drives: Scion FR-S (Hot Lava)
This is awesome! I've been looking for a solution like this for a while. Do you plan on doing a DIY guide once your done?
Seriously though, great work, I know this likely wasn't easy. I like your Video layout too. What are you using to record video, have you integrated a dashcam?
D18 is offline   Reply With Quote
Old 01-23-2016, 11:56 AM   #3
mabviper
Drives: WRB BRZ
Thanks! I don't know how easy it is to diy but I'm probably leaving towards open source software and hardware once it's done.
The video was recorded with my Sony AZ1 camera mounted on the tow hook. The data overlay is done in post using Dashware software. Awesome tool since it's now free. I made a profile for it so it automatically reads my data. I'm saving the data as CSV do it can be used with any data overlay software and analysis.
Unfortunately, in order to integrate a camera. You would need a much faster processor and support from the camera manufacturer to do the overlay in real time. Coincidentally, I do have a custom dashcam I made with Raspberry pi
Sent from my Nexus 4 using Tapatalk
Old 01-23-2016, 01:12 PM   #4
ottoyu34
ottoyu34's Avatar
Drives: Mazda3
About time, nice work sir!
ottoyu34 is offline   Reply With Quote
Old 01-23-2016, 07:10 PM   #5
ArCha
Drives: 2013 Subaru BRZ SWP
Really slick. I hadn't seen the two-lap overlay video before, very nice. Hopefully, I'll actually come out this year and see the setup in action.
Lee
ArCha is offline   Reply With Quote
Old 01-25-2016, 03:30 PM   #6
D18
D18's Avatar
I'll have to look into Dashware, never heard of it before. So it shouldn't be an issue to overlay on any video source, whether it be a dashcam or GoPro?
What are you using for datalogging, is it self built, or a purchased solution you've modified?
Old 01-25-2016, 03:33 PM   #7
D18
D18's Avatar
I'm really hoping that you've just used a Raspberry Pi and can upload us a wiring diagram and software lol.
Old 01-25-2016, 04:34 PM   #8
mabviper
Drives: WRB BRZ
Dashware will work with any video. Right now, it's running on a modified stm32 discovery board. A raspberry pi solution is definitely doable but I'm not confident the pi and Linux can process the data fast enough. I also can't buy the broadcom soc anywhere although with the release of the zero, it's now easier to get it integrated.
Old 01-26-2016, 10:50 AM   #9
Mazikowski
Drives: 2013 GBS BRZ Limited
Awesome work! Looking forward to seeing more as this progresses.
Subbed.
Mazikowski is offline   Reply With Quote
Old 05-27-2016, 07:50 PM   #10
mabviper
Drives: WRB BRZ
Just a little update on this project. It still works lol. I'll be field testing the system in Mosport DDT in a few weeks.
But for now, boards are in!
Old 06-06-2016, 11:19 AM   #11
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
@mabviper well done! I'm looking forward to seeing this bad boy progress.
BatStig is offline   Reply With Quote
Old 06-06-2016, 12:11 PM   #12
stevesnj
stevesnj's Avatar
Awesome stuff, I like the throttle and brake pressure. ala F1
My 2016 Build thread
Old 06-06-2016, 04:48 PM   #13
Rameus
Drives: 2015 FR-S
This looks great.
I had a little arduino based system running to display oil pressure in car, but my unreliably soldered wiring slowly wore down all my enthusiasm. I had plans of logging from the OBD2 port and eventually incorporating GPS support as well.
I'd be very interested to see your system in person sometime. Judging by the route you took in the video in your first post, it appears you aren't located that far from me.
Rameus is offline   Reply With Quote
Old 06-06-2016, 06:22 PM   #14
mabviper
Drives: WRB BRZ
Thanks guys. I can't wait to finally get this permanently incorporated in the car. I'm waiting for some major electronic parts like gps and wifi before I can start assembling the boards.
@Rameus I'm actually in the process of wiring up an oil pressure sensor and should be good to go. I'll be at CTMP DDT this Saturday to test the system out. If this is successful, I'll start working on code for gps lap timing.
Data Logger choices : Aim MXL2 - MXS - MXG philooo Tracking / Autocross / HPDE / Drifting 10 01-05-2023 09:48 AM
FS: Racelogic PerformanceBox Data Logger ft86Fan Miscellaneous 0 09-07-2015 05:26 PM
iPhone track data logger app? Wonderbar Tracking / Autocross / HPDE / Drifting 14 05-07-2013 03:31 PM
Solo Specific Data Logger.. VERY COOL Scooby South Tracking / Autocross / HPDE / Drifting 10 04-29-2013 10:54 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
