Old 01-22-2016, 04:29 PM   #1
OMGArisman
FRS Driver
Drives: Scion FRS
Rim Questions
As the title says I have a few questions about Wheels and Suspension Mods as i am quite a bit of a noob.
I am wanting to get XXR 527's
- Will 5x100 17x8.25 +25 Fit? (Photos If So) (I've Searched but wanted to narrow it down and see as many pics as i can)
- Will i need new lugs? If so what size?
- Will Stock Tires Fit? (temporary)
- What do camber bolts do?
- Will i need camber bolts if i decide to run lowering springs?
(Deciding between Eibach Prokit and the Sportline)
OMGArisman is offline   Reply With Quote
Old 01-22-2016, 04:33 PM   #2
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
The +25 offset might make it pretty close to the fender if not it may also pole
The lug size for our cars are m12x1.25
8.25 might work... Might. But it will stretch.
They adjust the knuckle position to give you camber. Up to 1.5 or 2 degrees depending on which bolts you use.
Instagram: trevor.parque
The Following 3 Users Say Thank You to MisterSheep For This Useful Post:
go_a_way1 (01-22-2016), Kami Speed (01-22-2016), OMGArisman (01-22-2016)
Old 01-22-2016, 04:36 PM   #3
OMGArisman
FRS Driver
Drives: Scion FRS
Thank you! Currently Looking around for pics now.
The Following User Says Thank You to OMGArisman For This Useful Post:
MisterSheep (01-22-2016)
Old 01-22-2016, 04:43 PM   #4
MisterSheep
Killed Scion
Usually when you change your wheels to aftermarket ones you should get better than oem lug nuts. Stuff that is thinner and could be used with a thin walled ratchet. Don't want to scratch your new rims do you? Also people, like me, option to changed their studs to ARP studs because they are much stronger than the oem studs as I have broken 3 so far. With the ARP studs then you will need extended lugs (if you want to hide the stud) Steel lug nuts will always be stronger than aluminum but will weigh more.
Old 01-22-2016, 04:47 PM   #5
OMGArisman
FRS Driver
Drives: Scion FRS
Haha reading on your post about recommended Lugs right now and its great thanks man
Old 01-22-2016, 04:49 PM   #6
MisterSheep
Killed Scion
Good luck
CAI/ OFT questions Account Attempt No. 4 Engine, Exhaust, Transmission 9 07-02-2015 02:56 PM
Wax Sealant Pad Questions / Care Questions l0aded Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 03-25-2014 11:19 AM
HID / LED questions RealShkillz Cosmetic Modification (Interior/Exterior/Lighting) 7 06-01-2013 05:15 AM
Questions about CEL DarkSunrise Issues | Warranty | Recalls / TSB 7 08-31-2012 12:42 PM
