Old 01-22-2016, 05:54 AM   #1
86Hiro
Using Carista App
Ive ordered a Carista Doggle to adapt to the OBD2 port, so I can add/delete factory options on my fiances car. Does anybody know if this app will clear CEL codes? Or does it just read them?
86Hiro is offline   Reply With Quote
Old 01-22-2016, 03:28 PM   #2
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
It can clear them as well, but only the paid version will do this not the free version
IceFyre13th is offline   Reply With Quote
Old 01-22-2016, 10:05 PM   #3
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I could've sworn that customizations were $20, I've had this app for like 2-3 years now and paid $20 once so I can change settings and it was totally worth it. Also with the beta version I have, you can register TPMS sensors if you have them in another set of rims
Old 01-23-2016, 09:48 PM   #4
86Hiro
Im just interested in the clearing of the CEL codes function. Im running catless UEL exhaust and I have the notorius CEL for being catless. I drive 35 minutes to work daily. Having the CEL on disables the Cruise Control and I hate having to pedal the throttle to get great gas mileage haha.
Old 01-24-2016, 05:25 AM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
If just for that .. i'd think more of getting normal ecu tune via ecutek or oft, to disable those CELs AND get bigger performance boost out of catless header.
The Following User Says Thank You to churchx For This Useful Post:
FRSBRZGT86FAN (01-27-2016)
Old 01-25-2016, 03:13 PM   #6
IceFyre13th
Drives: Mazdarati
+1
The Following User Says Thank You to IceFyre13th For This Useful Post:
Old 01-27-2016, 06:00 PM   #7
FRSBRZGT86FAN
+1
What IceFyre and Churchx said is important running with the P0420 CEL constantly coming up is kind of annoying, so you might as well get a tune, that way you can actually pass emissions and such, and make more power.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
wparsons (02-01-2016)
Old 02-01-2016, 09:51 AM   #8
Chimera
Drives: FRS
So this is something I have wondered about.. but not asked about or searched for..
If you disable a code, will the emissions scanners care, I always assumed yes, and planned to go to the oem tune for the test.
Old 02-01-2016, 11:59 AM   #9
FRSBRZGT86FAN
If you get a stage 2 tune like the openflash stage 2 tune for uel or EL headers, it disables the ability for the ECU to throw and show P0420 which creates an emissions readiness status when a mechanics plugs in there OBD-II scanner. The scanner can't tell it's been disabled or that you have a tune, it just says there are no errors and everything is running fine so it's a pass.
IF you go with the OEM tune it will fail because the scanner does multiple emissions readiness checks in a short period while the car is running and it will throw out the P0420 code even if you cleared the code out before the emissions test, and the scanner will notice the catalytic converter is well below performance (gone in fact).
If you get headers you should get a tune regardless, and your best bet if super worried is to swap on the stock headers for emissions testing if super worried with the OEM tune, in fact that's the only way the OEM tune would not throw a catalytic converter code, unless you had the OEM rom and edited out the P0420. @steve99 can probably elaborate
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
DAEMANO (02-01-2016), wparsons (02-01-2016)
Old 02-01-2016, 03:06 PM   #10
Chimera
Drives: FRS
I feel like I might be derailing this thread but..
I have the OEM header still and have been running e85 tune with the code disabled, but I planned to switch to OEM tune for the test, which I have never done one just yet as it hasn't come up. I was under the impression though that some scanners would know that you're supposed to have 2 readiness sensors b/c of make/model, and if you disable one it would know.
This suggests that Disabling the readiness sensor code for the header wouldn't trip a test though? or is this a question dependent perhaps on the tester?
Old 02-01-2016, 03:49 PM   #11
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Subbed cause im curious about emissions testing and tunes
PandaSPUR is offline   Reply With Quote
Old 02-01-2016, 03:59 PM   #12
FRSBRZGT86FAN
Your not disabling any of the O2 "readiness" sensors
Your only disabling Catalyst System Efficiency Below Threshold (Bank 1) not any of the codes related to O2 sensor voltage so it wont trip the test because the obd2 tool looks for readiness by making sure all the sensors are functioning and I think you only get 1 not ready on there scanner, which at least in my area is enough for a pass
Old 02-01-2016, 05:37 PM   #13
steve99
Its my understanding that you can disable the cel codes for say P0420 but this wont make the readyness show good as the sofware in ecu that checks the actual signals not just the cel set on
even ecutek does not force redyness checks to good, it probably a legal thing.
to pass readynes with cat codes disables somone would have to hack ecu software.
we dont have those checks where i live , but i am told that some states allow you to have one readyness check in not ready state and still pass.
torque app does the readyness checks not sure if carista shows them
generally if you disable code P0420 you will disable cel light and the cruise control will still work with no primary cat , but the readyness check will show incomplete for that check and some states may still fail you.
the guy running e85 tune on a completly stock car should go into the e85 tune as reenable the P0420 cel code, as he still has front cat P0420 should not trigger and with code enabled the readyness will pass.
Old 08-21-2016, 08:10 PM   #14
QHawk
QHawk's Avatar
Drives: 2020 86GT
Carista app pricing has changed. It's now $10 for one week and $40 for one year. "Look but don't touch anything" is still free.
So be careful when the app invites you to update. Previous pricing made this utility a sensible choice for personal use, but I wonder if the developers are overestimating the value of what they offer.
I also can't find a change log that might explain (i.e., justify) the new prices.
QHawk is offline   Reply With Quote
The Following User Says Thank You to QHawk For This Useful Post:
FRSBRZGT86FAN (06-08-2018)
Any Carista users? Need help... Tromatic Software Tuning 9 05-19-2014 09:49 PM
