Old 01-17-2016, 10:53 AM   #1
tracerit
Drives: '13 SSM BRZ Limited 6MT
Still dangerous to remove rear window tint and peeling the defroster lines?
I recall hearing about the danger when removing rear window tint that the defroster lines might be lifted and ruined in the past. Is this still something thst I should be concerned about still?
I have a high mount brake light thst I'd like to install but it requires using double sided adhesive and in the case that it melt off in high heat and take the tint with it, I just want to know if I should even proceed with this mod.
tracerit is offline   Reply With Quote
Old 10-20-2016, 10:55 PM   #2
PSim
Drives: BRZ or FR-S (soon)
I'm also curious about this. I'm considering buying a BRZ with tint that I'd like removed.
PSim is offline   Reply With Quote
Old 10-20-2016, 11:08 PM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
Guessing from past experience, the double-sided tape would give out long before the tint. That shit is on there practically for life.
Old 10-20-2016, 11:34 PM   #4
PSim
Are you saying that removing the tint risks hurting the defroster?
Old 10-20-2016, 11:44 PM   #5
TruRace
TruRace's Avatar
Drives: FRS-Raven-MT
I got my rear tint redone when I relocated my 3rd brake light. The guy doing the tint warned removing the existing tint could mess up the defroster and asked for my consent before proceeding. It ended up alright in the end.
TruRace is offline   Reply With Quote
Old 10-21-2016, 12:00 AM   #6
PSim
Is it expensive to replace the rear window if the defroster is damaged? Guessing it is.
Old 10-21-2016, 12:07 AM   #7
radroach
Drives: car
I've been thinking of removing the rear tint using a steamer, would that mess with the defroster?
Old 10-21-2016, 01:29 AM   #8
Ultramaroon
not playing cards
I very carefully used a heat gun years ago. It was awful because it left behind all the adhesive. Still had to follow up with a razor.
Old 10-21-2016, 04:09 AM   #9
churchx
churchx's Avatar
Drives: 2014 GT86
I'd rather be interested in some DIY mod of adding extra defroster lines to top area where relocated brake light is . I'm not sure how much/if lower Intec's sits, but Wheelhaus's is above existing defroster lines and unfortunately it is fogged or frosted for long after rest of rear window is clear. Then again existing lines won't be damaged due mount of that brake light (and it's doublesided adhesive strip being above them).
Old 10-21-2016, 08:31 AM   #10
skylinekin
skylinekin's Avatar
Drives: 22 GR86, 13 FRS, 15 BRZ, 13 FRS
Use a garmet steamer to release the adhesive, take your time and it shouldn't cause any damage. Try to pull the tint off in the direction of the defrost grid.
skylinekin is offline   Reply With Quote
Window Factory tint peeling? Packofcrows Issues | Warranty | Recalls / TSB 6 04-01-2015 09:30 AM
need help with rear defroster frstn Issues | Warranty | Recalls / TSB 9 04-15-2014 03:16 AM
Decal/sticker over defroster lines? samers66 Scion FR-S / Toyota 86 GT86 General Forum 5 09-23-2013 12:18 PM
side foam window peeling.. marky Scion FR-S / Toyota 86 GT86 General Forum 21 01-21-2013 06:39 PM
How to remove third brake light (to tint back window) 96z2 Cosmetic Modification (Interior/Exterior/Lighting) 10 06-07-2012 04:14 AM
