Drives: Scion FRS
Tie rods
Help me please!
So recently I bought l front lcas that adjust caster and camber. I want to go -5 degrees camber and oem spec caster (around 6). I definitely need tie rods, but haven't seen many comparisons or options out there. I need tie rods that are longer than oem. I maxed out my tie rods and it's not enough threads to fix toe out. Does anyone running a lot of camber have any suggestions as to correct toe or am I doing it wrong? CAMBER GOD'S PLEASE HELP! Sent from my SM-G920T using Tapatalk |
Drives: '24 GR86
Use camber plates...
By increasing camber via the LCA, you're widening the front track. Use the camber plate as well and you'll be able to achieve the same amount of camber, without running out of threads on the tie rods.
#3 | |
Drives: Scion FRS
| inner tie rods | BrightSlide | BRZ First-Gen (2012+) — General Topics | 2 | 07-08-2015 09:18 PM |
| apr splitter with rods | riironman | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 08-06-2014 12:30 PM |
| looking to buy the apr windsplitter with rods | riironman | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 07-07-2014 10:30 AM |
