03-24-2023, 12:43 PM | #71 |
義理チョコ
I thought they came with them. I have two sets of four blocks. One a bit taller than the other.
04-07-2023, 03:48 PM | #72 |
Drives: 2018 Subaru BRZ
SARD FRP wing installed. See my instruction guide below.
SARD Wing Install with OEM Holes Covering https://r.tapatalk.com/shareLink/top...ink_source=app |
The Following 3 Users Say Thank You to spcmafia For This Useful Post: |
04-07-2023, 04:31 PM | #73 |
Drives: Toyota GT86
Loving the look of the wing. Thanks for the guide as well
2014 GT86 Orange 6 Speed https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
The Following User Says Thank You to autoracer86 For This Useful Post: | spcmafia (04-10-2023) |
04-10-2023, 07:16 AM | #74 |
04-17-2023, 08:09 PM | #75 |
When in Gettysburg
05-02-2023, 06:59 AM | #76 |
A few updates;
For about a year, the vehicle started making a metallic, ticking noise. It became more preeminent when the vehicle was warmed up, and would only go away whenever applying little to full pressure to the clutch pedal. I greased everything that I could, did two fluid replacements, nothing changed. Until finally I caved in about the possibility that it might be my throwout bearing (TOB). So I got all my parts together, and went to work. Mind you this was the very first time I took on a more advanced repair by myself. There were a couple of freak moments, but in the end, after countless thread updates and YouTube videos, the repair was finished. Thread here https://www.ft86club.com/forums/show...28#post3579028 I took the opportunity to change fluids and went with AMSOIL. Probably the best decision I've made regarding Engine, Transmission, and Differential fluids. Everything feels so silky smooth and the car feels so much different. Highly recommend to make the switch. New parts installed are: Verus Engineering Clutch Fork and Pivot Revised TOB (OEM) Schaeffler Slave Cylinder Whiteline Transmission Insert |
05-02-2023, 10:24 AM | #77 |
Drives: Toyota GT86
I switched over to asmoil as well just in the transmission at the moment. Like you I found it to be very smooth
The Following User Says Thank You to autoracer86 For This Useful Post: | spcmafia (05-02-2023) |
05-02-2023, 07:47 PM | #78 |
Site Moderator
Drives: ichi 86 Project
Hopefully you replaced bearing retainer when you replaced the TOB.
The Following User Says Thank You to ichitaka05 For This Useful Post: | Jdmjunkie (05-02-2023) |
05-02-2023, 08:14 PM | #79 |
The Following User Says Thank You to spcmafia For This Useful Post: | ichitaka05 (05-03-2023) |
05-31-2023, 11:27 AM | #80 |
Bilstein B14 PSS Installed.
The Following User Says Thank You to spcmafia For This Useful Post: | NoHaveMSG (05-31-2023) |
05-31-2023, 12:58 PM | #81 |
Drives: Crapcan
The Following User Says Thank You to NoHaveMSG For This Useful Post: | spcmafia (05-31-2023) |
05-31-2023, 01:34 PM | #82 |
05-31-2023, 04:05 PM | #83 |
spcmafia 18 BRZ
05-31-2023, 04:35 PM | #84 |
Drives: Crapcan
That happens. I would call ahead and ask if they handle lowered cars.
