BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
06-25-2018, 11:24 AM | #1 |
Out of town...Remove DCC Fuse or Battery ?
Hello,
I understand from the Svc Manual, there's a DCC Fuse (aka Direct Circuit Connection fuse or D/C Cut fuse) which the Factory remove before shipping the vehicle to dealer. Dealer are suppose to re-install the Fuse to the correct slot prior delivering the vehicle to customer. The Manual state this is to prevent battery consumption during shipping. So if you are going out-of-town for like 2/3 weeks, would it make sense to just remove the DCC Fuse or to remove the Neg Terminal of the battery ? (I will need to get tooling for the battery...14mm i suppose?) Anyone know if the DCC Fuse will disable everything (like disconnecting the battery), or it will only disable selected devices. Many Thanks |
06-25-2018, 11:47 AM | #2 |
Drives: Subaru BRZ
I wouldn't worry about the battery going out after 2-3 weeks.
The Following User Says Thank You to Code Monkey For This Useful Post: | Stang70Fastback (06-25-2018) |
06-25-2018, 11:56 AM | #3 |
A.K.A. Starlord
Drives: 2015 Series.Blue
It's only 2-3 weeks. Don't worry about it.
If you're going somewhere for 6 months, then maybe start thinking about battery things.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
06-25-2018, 12:30 PM | #4 |
The Gunshine State
Drives: '14 BRZ Limited
As others have said, that's a short time frame so I'd leave it alone.
Current DD: M235i |
06-25-2018, 01:55 PM | #5 |
Thanks Guys
Does that still apply if the battery is 2-3yrs old ? Also, if you disable the battery (fuse or remove terminal), any thought on whether it will reduce or increase the risk of theft (if not park inside private garage). Regards |
06-25-2018, 02:18 PM | #6 | ||
Drives: 2014 BRZ Limited
And yes, I'm sure it was the battery. I have a Duracell AGM in it now, and the problem is gone. My engine also used to stumble when I turned the lights on (from the first week I had it). I though it was just a quirk of the car, but that issue has stopped with the new battery as well. It amazes me that Subaru would ship the cars with such a piece of crap in it. |
The Following User Says Thank You to extrashaky For This Useful Post: | rvoll (06-25-2018) |
06-25-2018, 06:25 PM | #7 |
Drives: 17 Asphalt 86
If you are looking for piece of mind, your local parts store likely provides a battery test[most cases it is free] to determine the life cycle on the battery.
3 weeks isn't long enough to drain a good functioning battery. Just make sure you don't leave anything that could draw on the system while you are gone. |
Similar Threads | ||||
Code P2102 after blown fuse on battery terminal | Krewmaui | Engine, Exhaust, Transmission | 1 | 05-05-2017 11:41 PM |
Car Won't Start.. No Lights.. Not a battery or fuse issue.. | pleong | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 09-23-2015 04:45 PM |
Battery Terminal Fuse replaceable? | STS-V | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 03-14-2014 08:36 PM |
Battery Terminal Fuse replaceable? | STS-V | Electronics | Audio | NAV | Infotainment | 0 | 03-14-2014 08:23 PM |
will polishing your car to remove swirls remove opti-coat? | bacon_cheese_beer | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 11 | 10-25-2012 10:41 PM |
