12-06-2021, 12:50 PM | #113 | |
Drives: JRSC BRZ SOLD
12-06-2021, 01:44 PM | #114 | |
Drives: 2018 Subaru BRZ Limited with PP
12-06-2021, 01:50 PM | #115 | |
12-06-2021, 03:04 PM | #116 |
Again, I see your point, but it's just not fully conclusive enough yet to say which will be faster IMO. Showing me a modified car race such as this civic tells me nothing as I have no clue how good this tune is, whether this dyno was high reading or low reading, what weight it's at, etc... So telling me "that wasn't a thing before" tells me nothing as it's a very specific comparison to make. Not sure that there are videos of fully tuned up gen1's vs a 210 whp k20 civic that we can compare to. I prefer comparisons that we know true numbers to. Gen1 header+e85 twins have plenty of videos smoking stock WRX's by a wide margin including from a dig, and staying even with a stock STI from a roll. These can also be dictated as poor comparisons because AWD vs RWD and weight definitely plays a big role as well.
Like I said, there has already been a video posted by CSG Mike trying to outpace a stock BRZ on a long straight, and it just wasn't happening, at least not very quickly. So it'll be interesting to see some real lap data on track comparing a fully tuned up gen1 to a stock gen2, if such data will ever come to exist. |
12-06-2021, 03:38 PM | #117 | ||
Drives: '23 BRZ
https://www.caranddriver.com/reviews...l-test-review/ https://www.caranddriver.com/reviews...-drive-review/ The tS PS4 tires didn't even help it get to 60mph quicker vs. Primacies. In fact it's the same 0.1s behind at 60mph and at the 1/4-mile. At higher speeds, the added drag of the wing of course will come into play. But if there's already a 0.1s time deficit at 60mph, I think it's pretty safe to conclude that the PS4 tires don't really help straight-line acceleration vs. Primacies. Worth noting that PS4 are not optimized for dragstrip launches but more for handling performance. Quote:
That drag run you reference where an E85 car ran 100mph at 13.58 on Hoosiers, you can tell that the ET vs. trap speed aren't "normal" due to the much grippier tires. On "normal" street tires, 100mph trap speed would be about 14.0s. Put that car on either Primacies or PS4 tires, and I would bet it hits ~99mph at ~14.1. I.e., much slower time but nearly same mph. |
12-06-2021, 06:13 PM | #118 | ||
Drives: 2022 GR86
Cars that are doing 0–60 in 2's and 3's are traction limited for a long time, and a 10% change in traction (ballpark for Primacy vs PS4) does account for up to 10% difference in acceleration rates for a significant chunk of the 0–60 or quarter mile. Even with 2.4 engines, BRZ/86/FRS cars have so little power (relative to Tesla/supercars) that they are power limited all the time, unless you first accumulate excess energy in the flywheel and then do a clutch dump / clutch slip. At least I've never seen them spinning rear wheels in 1st gear in a straight line in dry without utilizing the flywheel energy. Assuming the initial flywheel-to-kinetic-energy conversion takes less than a second on these cars, the 10% difference in traction gives us less than 0.1s of difference. Quote:
I will also compare my '22 data with someone who has a 4-2-1 catless header and a few more power mods (not sure about E85) if I get his permission. |
The Following User Says Thank You to timurrrr For This Useful Post: | Dzmitry (12-07-2021) |
12-07-2021, 12:37 AM | #119 | |
Dismember
Drives: 2013 Red Scion FR-S
12-07-2021, 08:54 AM | #120 | |
I just figured that's why there's such a large variation for people with 0-60 times (anywhere between high 5's to 8's) because it's a struggle to get the perfect launch with the right amount of grip on the tires. So based on that, I assumed grippier tires get a better launch, obviously with skill involved as well. Guess this isn't exactly that simple. |
12-07-2021, 09:23 AM | #121 | |
Drives: '23 BRZ
Again, referring to your referenced 13.58 run at 100mph, that's just never going to happen for a nose-heavy FR car on normal street tires on a non-traction-compounded surface. That time doesn't tell us much about that car's power/weight vs. a stock car on normal tarmac (whether on Primacies or PS4). However the trap speed does give us a clue... It's important to keep as much as possible similar between tests. Which is why I always quote Car and Driver tests, because they have a consistent procedure and are testing totally stock cars. Their *trap speeds* are a pretty reliable way to judge a car's power/weight, particularly comparing cars that are very similar like gen1 and gen2. |
The Following User Says Thank You to ZDan For This Useful Post: | Dzmitry (12-07-2021) |
12-07-2021, 09:26 AM | #122 | |
Drives: 2022 BRZ (Base, Red)
That said, the new car has a 6 mph increase in trap speed (101 mph vs. 95 mph), which is a decent improvement given that trap speed is roughly proportional to the [s]square[/s] cube root of power to weight ratio. More significantly, it has around 35% more torque at 4000 RPM, which makes a huge improvement in everyday performance. In a quarter mile race, you can stay above the torque dip of the old car, so the trap speed difference, while significant, isn’t quite as huge. However, in everyday driving, acceleration is done in the 3000-4500 RPM range where the old car falls flat, and the new car has almost 30% more torque on average. Keeping in mind that you’re using around 25-35% of the old car’s torque to maintain speed in fifth or sixth gear highway cruising, the mid range torque increase becomes even more accentuated as a 50% or more increase in mid range highway acceleration. Try accelerating from 65-80 mph in fifth gear - the difference between the old and new cars would feel massive. Last edited by wizee; 12-07-2021 at 10:00 AM. |
12-07-2021, 09:28 AM | #123 | |
Drives: '23 BRZ
101mph vs. 95mph in the quarter implies (101/95)^3 = 1.20x, or 20% more power. |
The Following User Says Thank You to ZDan For This Useful Post: | Yoshoobaroo (12-07-2021) |
12-07-2021, 09:55 AM | #124 | |
Ah yes, I screwed up the derivation in my mind. Speed after a fixed amount of time is proportional to square root of power. Speed after a fixed amount of distance is proportional to the cube root of power. |
The Following 3 Users Say Thank You to wizee For This Useful Post: |
12-07-2021, 10:10 AM | #125 |
TRACKBREAD
Car & Driver Comparison Test Review: Veloster N vs. GTI vs. BRZ vs. GR86
So a 20% increase lines up with the dyno whp differences as well. Seems pretty cut and dry that the new cars are making 20% more power at the wheels than the 2013s. Functionally it’s a 240hp car underrated to 228.
When all roads lead to Rome, the shoe fits and it quacks like a duck or something like that. |
The Following 6 Users Say Thank You to Yoshoobaroo For This Useful Post: | bhmax (12-10-2021), DarkSunrise (12-07-2021), Dzmitry (12-07-2021), Robertw (12-07-2021), Sport-Tech (12-07-2021), ZDan (12-07-2021) |
12-07-2021, 10:20 AM | #126 |
Drives: 1996 Turbo Miata
I liked the part in this thread where a stickered on rear spoiler is adding drag and impacting 1/4 times or speed. I've been off forums for a little bit, and man I missed them.
Similar Threads | ||||
GR86/BRZ Comparison Articles | Kona61 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 74 | 01-02-2022 08:39 AM |
GR86/BRZ Track Comparison (Japanese) | Kona61 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 95 | 12-24-2021 06:36 PM |
2022 GR86 & BRZ Post Serious Performance Numbers (Nearly 1g Skidpad)! [C&D Review] | Hachiroku | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 3 | 11-24-2021 07:18 AM |
Drift King Video Test: Gazoo Racing GR86 vs. BRZ STI | TofuJoe | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 03-15-2018 08:21 PM |
what will be the BRZ first comparison test? | BMWDAD | BRZ First-Gen (2012+) -- General Topics | 8 | 12-18-2011 03:47 PM |
