Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
09-28-2015, 01:57 PM | #15 | |
Drives: 2015 FRS
2015 FRS Ultramarine.
09-28-2015, 02:11 PM | #16 | |
The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | SkiRideDrive (09-28-2015), wparsons (10-02-2015) |
09-28-2015, 02:30 PM | #17 |
Dismember
Drives: 2013 Red Scion FR-S
Am I weird for not considering formula sae as real formula cars?
The Following User Says Thank You to EAGLE5 For This Useful Post: | wparsons (10-02-2015) |
09-28-2015, 03:14 PM | #18 |
Drives: 2015 FRS
Classify them however you like.
09-28-2015, 11:38 PM | #19 |
Dismember
Wasn't an insult. Just never thought of them as formula cars.
09-28-2015, 11:40 PM | #20 |
Drives: 2015 FRS
I've interpreted formula as an open wheel car designed to a set of rules and assumed that FSAE fit within that envelope.
09-30-2015, 01:19 AM | #21 |
Drives: 2015 FRS
Alright, solving the camber issue.
From my research. I can take the bottom strut bolt and put it in the top hole, and put the SPC 81260 14mm camber bolt in the lower hole to achieve about 2 degrees of negative camber. It also seems that each degree of negative camber seems to add about 1/16" of toe in per tire. Can anyone confirm? Also, does anyone know the ratio of tie rod turns per 1/16" of toe? This would speed up my alignment considerably. Thanks!
09-30-2015, 03:22 AM | #22 |
[insert cool phrase here]
Drives: BRZ Premium
Yes that the correct way to install crash bolts.
As for the toe setting. You really can't guess it with out having proper measuring tools. Unless you have a toe setting plate and doing the the whole string and plumb deal, your best and fastest way is to take it to a shop. Sure it may cost a few dollars but it's a lot better than a DIY route. Unless you have alignment tools.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
The Following 2 Users Say Thank You to Mr.ac For This Useful Post: | SkiRideDrive (09-30-2015), wparsons (10-02-2015) |
09-30-2015, 10:14 AM | #23 | |
Drives: 2015 FRS
09-30-2015, 01:20 PM | #24 | |
Drives: '14 WRB BRZ Limited
Not sure if you'll be back on stock tires, but I was most comfortable with about 35 psi front / 34 psi rear "hot" (as soon as I parked after I came off of the track) on a 100* day on stock tires. Set "cold" before my next session (about 2hrs between sessions) here in New Orleans, I was at about 31 in the rear, and 32 in the front. The following day I forgot to put air in the tires after leaving the track and my dummy lights were on for the tires (all <25psi) at about 75* in the morning. I felt like the rear starts to slide a little bit and the front understeers with 2psi more air than that. With 2psi too little air, the car feels more "squishy" like it doesn't want to settle when I was transitioning through "S" curves. That could just be me though, I'm still pretty new to all of this track day business (only 4 days on the NOLA track). And this was on bone stock suspension/camber/tires. |
The Following 2 Users Say Thank You to dustmann For This Useful Post: | DocWalt (10-05-2015), SkiRideDrive (09-30-2015) |
10-01-2015, 12:54 PM | #25 |
Drives: 2015 FRS
Thanks for the input.
I actually found a deal on a few used stock tires so I am going to swap out the chunked tire for now in the canyons and work on a solution for track days. I also ordered the camber bolts and will install them soon.
10-05-2015, 04:03 PM | #26 |
Drives: '22 BRZ
Thanks for the input on tire pressures for stock tires. I've got my first track day coming up in the BRZ and I don't feel like buying real tires for one track day then leaving them sit all winter. That said, maybe chunking the stock tires will let me justify better rubber sooner
Similar Threads | ||||
Widest Track tires for stock wheels?? | track_warrior | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 56 | 10-11-2015 11:01 AM |
WTB Stock Tires or Tires that would fit on stock rims. | DrawingWaves | Want-To-Buy Requests | 2 | 09-11-2015 09:03 PM |
Anyone running stock rims with good tires for open track? | suaveflooder | Tracking / Autocross / HPDE / Drifting | 36 | 09-10-2014 08:49 AM |
Track-only Race Compound Tires recommendations & Q's. On stock wheels. | fooddude | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 03-26-2014 11:47 PM |
good track tyres for the track? stock rims | Rejor11 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 17 | 07-22-2013 12:35 AM |
