Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
08-05-2019, 07:50 PM | #29 |
Drives: '13 Whiteout
Any feedback on the Jackson Racing unit? Not the radiator\oil cooler combo but the oil cooler they offer?
08-05-2019, 09:22 PM | #30 |
The Following 3 Users Say Thank You to Grady For This Useful Post: |
08-06-2019, 02:14 AM | #32 |
Great kit. Plug and play, and doesn't mount to the bottom. This is important if you have an unwanted off-track excursion; you don't want to rip off your oil cooler.
08-08-2019, 10:21 AM | #33 |
08-08-2019, 10:54 AM | #34 | |
In many cases, it's an either or scenario. As in...it does the job effectively, or it does not do the job effectively. Speaking broadly (not just about oil coolers or any brand names), for some parts there is NO in between for success and failure. Or alternatively a part might work...until it doesn't and the consequences are substantial. Function over a short time scale is one thing. Sometimes the value added is convenience, ease-of-installation, your time, after-sale support, compatibility with other parts, reliability, etc.. It's up to you to decide how much that is worth. This doesn't mean you can put together your own kit that is just as good as the really nice off-the-shelf stuff. Some of y'all have serious skills and that's awesome. It just takes time, knowledge, serious attention to detail, and risk. The risk changes depending on the part, but with something like an oil-cooler it's a bit more. - Andrew Last edited by Racecomp Engineering; 08-08-2019 at 12:38 PM. |
08-08-2019, 12:58 PM | #35 | |
義理チョコ
If you decide to try it for yourself, beware of the asymmetry of the bracket positions. I blew it the first try because I made a bad assumption.
The Following User Says Thank You to Ultramaroon For This Useful Post: | Tristor (08-08-2019) |
08-08-2019, 02:21 PM | #36 |
BoostedBRZ
Drives: Turbo BRZ
Really??
Setrab 19 row: $186 https://www.amazon.com/Setrab-ProLin.../dp/B00TO6BU5K fittings for oil cooler:$68 (qty 2, 34 each) https://www.pegasusautoracing.com/pr...gaAv8PEALw_wcB RacerX Fab Sandwich plate, spacer, and fittings: $145 http://racerxfabrication.com/frs-brz...-adapter-plate Aeroquip -10an hose 15ft: $80 https://www.amazon.com/Aeroquip-FCN1.../dp/B000CII15Q 2 remainder fittings to go on sandwich plate (BAT inc/Mocal): -10AN P45-10 $16.80x2 https://irp-cdn.multiscreensite.com/...ed/phosend.pdf https://www.batinc.net/#PRODUCTS miscellaneous hardware/brackets: ~~~ whatever you want about 515 dollars. This setup is very similar setup to what I have, except I have a mishimoto core. I have had ZERO issues with my core, but that's the only mishimoto thing on my car. I didn't want setrab because it was black and I wanted an oil cooler with no coating due to this video: [ame]https://www.youtube.com/watch?v=z_mmmXTbLP0[/ame] you're welcome. Edit: you can do alot of this for cheaper, but honestly, I wouldn't settle on any of the "fragola" or amazon generic fittings... some of those things are like 6.99 or cheaper.. Oil is a very important necessity for your engine. I wouldn't cheap out on that. At the very least get these name brands mentioned in this post for an inexpensive DIY setup. Like as others have said, you can definitely do it for WAY cheaper... 100 dollar oil cooler? or multi-thousand dollar engine rebuild? spend the few extra couple hundred bucks making a decent one and you'll be happy you did.
08-08-2019, 04:04 PM | #37 |
A lot of folks in this thread seem to be missing that the application-specific IP for an engine oil cooler is the MOUNTING BRACKET, which if you are building your own instead of using a kit requires you to fab yourself. Sure you can jank something together with L-channel from Home Depot, but it is not going to perform as well as a tested design. If you're a skilled fabricator, by all means go for it, but to suggest throwing something together yourself is a superior alternative to a branded application-specific kit simply due to cost is ignorant to the point of absurdity.
The Following User Says Thank You to Tristor For This Useful Post: | Ultramaroon (08-08-2019) |
08-08-2019, 06:49 PM | #38 |
義理チョコ
It was L-channel from Lowes, thank you very much.
08-08-2019, 08:08 PM | #39 | |
If you have the Setrab core that Jackson racing uses you would want to use their brackets. Jackson racing even offered to custom rig their intercooler mounts for my 613 core when I was researching all of this. All of the options I mentioned are sold separately from their kits. Some require a phone call or email. Edit: It actually seems you can only put 613 setrab cores or similar on the racer-x/perrin bumper mounts, 619 needs the crash beam support. Last edited by norcalpb; 08-08-2019 at 08:19 PM. |
08-09-2019, 08:24 AM | #40 |
https://www.scintex.com.au/products/...amping-showers
I might trial a 30 or 60 row, from a rough guesstimate, using my thumb as a measuring tool, a 30 plate is twice the size as the forester, and a 60 is 4 times. Should bring up temps nixe and quick and control oil temps well. Well, in theory, using my thumb as a measuring tool It's simular to this > https://www.pwr.com.au/products/oilc...ne-oil-coolers only cheaper Will need sandwich plate, lines and fittings Specs look good If I do I'll post up
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
The Following User Says Thank You to 86MLR For This Useful Post: | Ultramaroon (08-09-2019) |
Similar Threads | ||||
Oil coolers that will fit with the TRD intake? | Hanakuso | Engine, Exhaust, Transmission | 28 | 03-05-2022 11:24 AM |
Inexpensive Oil Coolers - worth it? | robwbright | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 28 | 05-10-2019 07:58 PM |
Oil coolers | Matey | Forced Induction | 37 | 03-13-2015 08:21 AM |
those with perrin oil coolers | bkblitzed | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 10 | 12-08-2013 12:34 AM |
HKS Oil Coolers in stock | Sam Strano | Engine, Exhaust, Bolt-Ons | 3 | 11-13-2012 01:41 PM |
