06-03-2014, 10:02 PM | #43 |
Drives: 2022 BRZ Limited
I've noticed that there is no How to /DIY for custom brake ducting so I created my own
http://www.ft86club.com/forums/showthread.php?t=67289
06-06-2014, 06:25 PM | #44 |
Ordered:
06-06-2014, 06:33 PM | #45 |
Gear/differential fluid and engine oil have been received,
Let's see if the moly content will help reduce the blowby gasses to a certain degree
06-09-2014, 04:25 PM | #46 |
Reflective tape seems to be working at track
Boomba racing vacuum check valve received and installed OEM ABS sensor ( no more ABS and traction ligths on the dash)
06-09-2014, 04:26 PM | #47 |
Schroth Rallye 3 w/ ASM driver side harness have been received .. I've also ordered optional padding and grips
06-13-2014, 06:58 PM | #48 |
FT-86 SpeedFactory Front Splitter has been received and install. I've also received my Cusco Accelerator pedal with the same shipment. It was a really straightforward installation, thanks again @FT-86 SpeedFactory for good quality product and great communication
and now on the car with my street tires and wheels since I will be driving to a track event this weekend I cannot wait to test this splitter at track and combine that with the Driveway Labs diffuser I recently ordered @Wonderbar
06-13-2014, 06:59 PM | #49 |
I've installed my new Invidia Catback so the fitment should not be an issue with the V1 diffuser
Cusco pedal will be installed tonight
The Following User Says Thank You to glamcem For This Useful Post: | Proof (06-15-2014) |
06-18-2014, 02:45 PM | #50 |
new track video has been added to the first post
07-05-2014, 07:50 PM | #51 |
Driveway Labs V1 Diffuser installed
Tail lights have been redded out Schroth harnesses have been installed XXR wheels have been installed Quick mini latches have been added Supporting rods for splitter have been added
07-05-2014, 07:51 PM | #52 |
The Following User Says Thank You to glamcem For This Useful Post: | Ganthrithor (11-22-2014) |
07-06-2014, 01:23 PM | #53 |
Which splitter support rods did you go with? How are they secured to the bumper?
07-06-2014, 07:26 PM | #54 |
These are the support rods
http://www.frsport.com/Aluminum-Spoi...niShPbLzvw_wcB And these are the backing disks http://www.frsport.com/Longacre-2370...t_p_66187.html You dont have to use support rods with this splitter since the splitter is attached from the bottom of the car with more than 10 rivet nuts(its track tested and notthjng happened even after i ran off the track once) sothey are currently attached to the bumper and gives me angle adjustability.. I will however, add the new brackets and fins once they release the upgrade kit
The Following User Says Thank You to glamcem For This Useful Post: | kster1 (07-06-2014) |
07-07-2014, 03:16 AM | #55 |
I have to mention though the new Race version will include the fins/vanes and support rods that will attach to the bumper crash beams, for those who look for the ultimate solution
07-11-2014, 01:28 AM | #56 |
Drives: '13 BRZ, '06 997, Other Things(TM)
How do you like the balance of the car with that splitter / diffuser combo? I'm thinking of getting the same setup for my car because braking down from triple-digit speeds feels so sketchy stock.
The Following User Says Thank You to Ganthrithor For This Useful Post: | glamcem (07-12-2014) |
Similar Threads | ||||
Supercharger Comparison: Innovate, Jackson, Kraftwerks, Vortech *Updated March 9 2014 | CSG Mike | Forced Induction | 281 | 02-25-2021 04:14 AM |
Pneubs HKS Supercharged BRZ Build Thread | Pneub | Member's Car Journals | 62 | 03-30-2016 09:47 AM |
Dezoris | FR-S Build | Supercharged & More | Dezoris | Member's Car Journals | 329 | 03-21-2016 04:48 PM |
Morpheus, Scion dream Build. Supercharged FR-S by TuneCast | scionsalesjay | Member's Car Journals | 51 | 07-07-2014 12:05 PM |
Supercharged Rocket Bunny Widebody Conversion Build Thread | RWDRIFT | Member's Car Journals | 278 | 01-06-2014 12:12 AM |
