Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
01-08-2016, 02:58 AM | #29 | |
Inactive
Drives: .
04-30-2019, 06:29 PM | #30 |
Drives: 2018 Subaru BRZ Premium
My 2018 BRZ just started doing this today, have almost 700 miles on it and on my way to work I was in a hurry and ran to about 6k RPMand noticed the rattling sound, I’m taking to to Subaru on my next day off hope it’s something fixable cause that will drive me crazy
04-30-2019, 06:43 PM | #31 | |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
http://www.ft86club.com/forums/showthread.php?t=134052 shifter rattle is very common for this platform. I used to get it every time I was revving past 5 K in 2nd gear for about the first 20 K miles from new, then it disappeared for quite some time until the other day I heard it come up a couple of times and I'm going to be hitting 60 K soon. Taking it to the dealer is a waste of time and will only frustrate you. People on this forum have changed out many bits of the shifter assembly like the OP, have added extra padding and some were even able to convince their dealer to replace their entire transmission just due to shifter rattles only for the rattles to come back! There are going to be a lot of odd mechanical sounds from this platform, best to either roll down the windows, get a louder exhaust or install a sub and crank up the beatz. |
04-30-2019, 08:47 PM | #32 | |
04-30-2019, 08:55 PM | #33 | |
Reformed
https://www.google.com/search?rlz=1C...71.nOjSgQaoy20 yes, cars are expensive but that is why you have insurance and warranties...your preliminary sound concerns will not discover any issues before parts actually break. Just drive the machine |
05-23-2019, 09:40 PM | #34 |
Drives: 86 GT
Hi guys, another shifter rattle issue here which I just realised recently.
I got mine used, about 48k miles. Was pushing it on the straight on 2nd and it would rattle past 4.5k RPM. Now it could either be two of these problems: 1. Nylon bushing rattling - https://www.ft86club.com/forums/showthread.php?t=50512 2. Washer between lever and rod - http://www.ft86club.com/forums/showthread.php?p=2170681 Problem is, how do I identify which issue I'm facing? Currently I don't have access to my car at the moment but will try out any options you guys have to diagnose it before finding a solution. |
The Following User Says Thank You to Compelica For This Useful Post: | sato (09-08-2020) |
06-11-2019, 10:33 PM | #35 |
Drives: 2018 BRZ tS
FIXED THE RATTLE! (mostly)
I have an '18 tS, and my shifter rattled pretty bad over 4000rpm, and was annoying the crap out of me. The car is under warrantee so I tried the dealer, but the blamed the carbon fiber driveshaft I have on the car, which I wasn't about to swap off just to prove the rattle was still there without it (which it was). Then I tried the Perrin billet lockout lever, and the rattle is reduced about 75%. Still happens, but in a much narrower rpm range and it's far more subdued - to the point of not being noticeable. Recommended. |
08-13-2020, 06:23 AM | #36 | |
Drives: BRZ 2017 type S
it happens on my 2017 brz, totally same |
08-13-2020, 06:47 AM | #37 |
I believe to change a better rubber o-ring at the base of the shift lever should be the key point to solve the rattle
08-13-2020, 02:58 PM | #38 |
In my case the rattle comes from the reverse spring (if you pull it up, there's no rattle). I put a ton of grase around the spring, but it lasts till the vibrations clean it out.
I accept suggestions... |
Similar Threads | ||||
Audible shifter rattle | Hanzo | Issues | Warranty | Recalls / TSB | 134 | 08-17-2022 02:34 AM |
How much shifter play is normal? | radroach | Engine, Exhaust, Transmission | 16 | 08-02-2017 10:25 PM |
Shifter rattle WOT over 4500rpm | Khorne | Issues | Warranty | Recalls / TSB | 25 | 10-19-2015 10:49 PM |
rattle from shifter at 5k.+ rpm | MurderRider | Issues | Warranty | Recalls / TSB | 11 | 02-01-2015 05:02 AM |
BRZ Shifter Rattle TSB | sc0urge | BRZ First-Gen (2012+) -- General Topics | 2 | 08-26-2013 08:53 PM |
