03-17-2014, 10:32 PM | #351 |
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
1.24 is the version of the OFT firmware, which is different from the OTS tunes. Nothing for you to update at this time.
- AdrianG |
The Following 2 Users Say Thank You to AdrianG For This Useful Post: | Shiv@Openflash (03-17-2014), Sirsimon (03-17-2014) |
03-17-2014, 10:59 PM | #352 | |
Drives: SWP BRZ
mine looks ok? if i compare previous tune of v1.42 VS 1.56b, i feel much smoother than before. |
03-18-2014, 12:12 AM | #353 |
Drives: Toyota 86 Turbo, Lexus NX300H
@shiv@vishnu
I use JDL UEL with OFT OTS stage 2 map via ECUtek cable. ( and MY OFT is shipped to my country , it will be here this week. ) Flickr에서 Yobi-Wan님의 datazap-chart (1) http://www.datazap.me/u/yobiwan/v16-...7&zoom=606-761 I did maf rescaling my self. and there are AFR mismatch in 3000~4500 range. I can't fix that area with MAF scaling. I tried several times. but nothing work. ( http://www.datazap.me/u/yobiwan/oft-...3&zoom=325-481 http://www.datazap.me/u/yobiwan/maf-...3&zoom=199-357 http://www.datazap.me/u/yobiwan/oft-...-5&zoom=47-268 ) What should I do for this problem ? my suspicion is it's due to "not perfectly fitting cam table" should I buy E-tuning option? or is there any way to adjust my self? |
03-18-2014, 12:19 AM | #354 | |
Drives: 2013 FRS
The Following User Says Thank You to Shiv@Openflash For This Useful Post: | zc06_kisstherain (03-19-2014) |
03-18-2014, 02:19 AM | #355 | |
Drives: FT86
Have you disabled fuel trims ?? noticed STFT and LTFT are always zero or you have wrong RAM addresses for those parameters for logging. |
03-18-2014, 02:24 AM | #356 |
Drives: SWP FR-S
so whats this i hear about v1.6? @shiv@vishnu
03-18-2014, 02:36 AM | #357 | |
if you zoom out that log, you can see LTFT & STFT http://www.datazap.me/u/yobiwan/v16-...g=0&data=3-6-7 but I did that log right after tune. so it moved not so much. LTFT of that range ( 3000~5000) will be -4~-6 eventually like this log http://www.datazap.me/u/yobiwan/test-log?log=0&data=1-4 I attatched another post learned log capture too. STLT & LTFT works fine. Last edited by Yobiwan; 03-18-2014 at 06:24 PM. |
03-18-2014, 02:44 AM | #358 | |
Drives: FT86
even in that log the fuel trims seem incredibly stable at 0 to 0.8 even when your on and off the throttle you will have to wait for some experts to come and look at it |
The Following User Says Thank You to steve99 For This Useful Post: | Yobiwan (03-18-2014) |
03-18-2014, 03:51 AM | #359 |
Addicted
Drives: 2013 Asphalt FR-S 6MT
Don't know if this is the right thead but just pulled the trigger =). Can't wait to see what the hype is all about and excited for FI options in the future.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
03-18-2014, 08:08 AM | #360 | |
Small and stable trims = well scaled MAF
03-18-2014, 12:16 PM | #361 | |
Drives: 86
log and AFR
http://www.datazap.me/u/haririmm/155...ata=1-2-7-9-11 I did 3 runs starting in third and then shifting to fourth. Below video for the second run. Note, Speed is in KM/H [ame]http://youtu.be/6rM7MYMn5hk[/ame] Appreciate your comments
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
03-18-2014, 07:02 PM | #362 | |
Drives: FT86
Would be good to know the exact logic ie x number of fbkc events greater than y value in time period z causes coarse correction, but its probably more complex. The stuff on RR is ok but its for WRX ECU so imagine may not apply totally to FA20 Yep agree with that, they did seem incredibly stable though with large throttle movements Last edited by steve99; 03-18-2014 at 07:14 PM. |
03-18-2014, 07:06 PM | #363 | |
Drives: 2013 FRS
03-18-2014, 08:13 PM | #364 | |
With a quick glance i see what looks like possibly minor FLKC @ 3600-~4600 and then from 5200 to 5800 again some minor FLKC. This is minor knock but if you are getting it at the 5200+ mark running that rich some minor timing may need to be pulled from the ignition map. Also what fuel are you on?
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
The Following User Says Thank You to nelsmar For This Useful Post: | 8686 (03-18-2014) |
Similar Threads | ||||
OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 06:35 PM |
FS: Openflash Tablet | Sgt.Beardface | Engine, Exhaust, Bolt-Ons | 8 | 01-04-2014 11:12 AM |
FS: Openflash tablet | nguyen_er | Engine, Exhaust, Bolt-Ons | 6 | 12-30-2013 12:31 PM |
new OpenFlash tablet | autobrz | Engine, Exhaust, Bolt-Ons | 5 | 12-23-2013 09:05 AM |
WTB Openflash Tablet | Vlady | Want-To-Buy Requests | 0 | 10-25-2013 12:10 AM |
