Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
08-04-2019, 07:57 PM | #15 | |
Drives: '13 Whiteout
08-04-2019, 08:15 PM | #16 |
義理チョコ
When I have it running wide open, I can bury the tach all day long and it stays rock solid at 190F. I bypass about half when cruising.
08-04-2019, 08:25 PM | #17 |
Mishimoto have a brand name to protect, so, quality assurance on the line is greater.
I've used quite a few Mishimoto parts and have never had a issue with parts fitting. Convenience costs Give me convenience or give me death
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
08-04-2019, 08:32 PM | #18 |
Opps, forgot my main point
I feel the Forester heat exchanger thingie works best to bring up temps from cold, as a cooler there is minimal benifit. While I have been NA the Forester item has been gold, I'll see how it handles the added temp from cooling a turbo, I really cannot see it being a issue, even in 40°+ temps as the 86 is a street car only. If it is a issue, a Mishimoto or a AVO oil cooler will be fitted, thermostat controled of course.
The Following User Says Thank You to 86MLR For This Useful Post: | Ultramaroon (08-04-2019) |
08-04-2019, 09:29 PM | #19 |
Drives: 2017 BRZ PP , 2005 Saab 97X
08-05-2019, 07:22 AM | #20 |
JHerbert Racing
Drives: 2013 Scion FRS
The maximal oil cooler kit is a good, budget friendly unit if you can think of a way to mount the core yourself. You can upgrade the core if you track somewhere it is always hot and they will custom make the lines if you want to mount it somewhere funky.
08-05-2019, 03:33 PM | #21 | |
More than a few Mishimoto coolers have backed off at the track, resulting in engine fires. |
The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
08-05-2019, 03:41 PM | #22 |
This guy is selling a thermostatic plate, oil filter adapter, and tube for $100. All you’d need is a core ($160), core mounts ($40) and the hoses/AN fittings ($50)
08-05-2019, 04:09 PM | #23 | |
interesting..... Always good to axe questions. Last edited by TommyW; 08-05-2019 at 04:25 PM. |
08-05-2019, 04:22 PM | #24 |
Drives: FRS
08-05-2019, 06:43 PM | #25 |
Banjo fitting are not bad. However you do need to know their weaknesses. (A) The hoses need a lot of space to not put a load on the fittings during engine flex. This is difficult in our tight engine compartment. (B) They have to be torqued correct. (C) A banjo fitting should be safetied period. Any one of the 3 items listed above done incorrectly will not cause an issue. You will need 2 mistakes to cause an issue. I like the plate due to the clearance with the 2017+ air box.
This was my fix. I have no worries about mine coming loose. |
The Following User Says Thank You to Grady For This Useful Post: | NoHaveMSG (08-05-2019) |
08-05-2019, 06:54 PM | #27 | |
Banjo fittings are everywhere From my experience 99% of issues people have when using brand name parts are due to incorrect install procedures.
08-05-2019, 07:30 PM | #28 |
Similar Threads | ||||
Oil coolers that will fit with the TRD intake? | Hanakuso | Engine, Exhaust, Transmission | 28 | 03-05-2022 11:24 AM |
Inexpensive Oil Coolers - worth it? | robwbright | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 28 | 05-10-2019 07:58 PM |
Oil coolers | Matey | Forced Induction | 37 | 03-13-2015 08:21 AM |
those with perrin oil coolers | bkblitzed | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 10 | 12-08-2013 12:34 AM |
HKS Oil Coolers in stock | Sam Strano | Engine, Exhaust, Bolt-Ons | 3 | 11-13-2012 01:41 PM |
