Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
12-26-2016, 08:30 PM | #1 |
Drives: 2014 Asphalt FRS
Decreased mpg due to mud guards?
Hey guys Ft86club community. I recently bought a 2014 Asphalt FRS about 2 weeks ago . Really excited about the car! I do have a question though(topic title). Is that possible? I haven't really noticed a difference yet since I haven't driven the car in the highway with them installed but just an idea... I just recently installed them as well.(OEM)
12-26-2016, 09:22 PM | #2 |
doubt it. your driving habits will affect MPG the most
The Following User Says Thank You to ryoma For This Useful Post: | tCsonfrs (12-30-2016) |
12-26-2016, 09:56 PM | #3 |
Drives: Silver FR-S
The OEM ones are pretty skinny and work well with the stock wheels. The wide rally armor flaps are more likely to cause significant drag. But idk how much more likely.
Sent from my SAMSUNG-SM-G935A using Tapatalk |
12-27-2016, 12:19 PM | #4 |
what color are they?
12-27-2016, 12:38 PM | #5 |
You're joking.. Right?
The Following User Says Thank You to D_Thissen For This Useful Post: | tCsonfrs (12-30-2016) |
12-27-2016, 12:44 PM | #6 |
Weight Weenie
Drives: 15 FR-S
Just add some of these and you'll even out.
The Following User Says Thank You to new2subaru For This Useful Post: | Mo7ammed (12-28-2016) |
12-27-2016, 12:48 PM | #7 |
The Gunshine State
Drives: '14 BRZ Limited
Drill some speed holes in the mudflaps for IMPROVED MPGs.
Current DD: M235i |
12-27-2016, 01:43 PM | #8 |
Drives: Subaru BRZ
Speed holes?? Is this like a vortex cyclone device that creates a vacuum on the attacking face thus sucking air through creating rush on back face that aids drag reduction and gives a positive airflow pattern that helps to self clean the car?
The Following User Says Thank You to JD001 For This Useful Post: | geezerbrzeezer (12-27-2016) |
12-27-2016, 02:05 PM | #9 |
The Gunshine State
Precisely!
Current DD: M235i |
The Following User Says Thank You to 8RZ For This Useful Post: | JD001 (12-27-2016) |
12-27-2016, 02:39 PM | #10 |
Geezer
Drives: 2016 Subaru BRZ Sport Tech
From the manual:
"After the installation of OEM mud flaps, three important steps must be taken: 1 - decrease the normally recommended tire pressure in each tire by 20 psi so that the reduced tire/wheel weight and (lowered vehicle) drag reduction will offset the mud flap drag effect on mpg numbers; 2 - increase the normally recommended tire pressure in each tire by 20 psi so that the reduced rolling resistance will offset the mud flap drag and tire pressure reduction instructions (in step 1 above) effect on mpg numbers; 3 - shine a flashlight into your left ear - a beam visible from your right ear means you're on empty - contact your dealer." |
The Following User Says Thank You to geezerbrzeezer For This Useful Post: | JD001 (12-27-2016) |
12-28-2016, 03:32 AM | #11 |
Thanks guys for some feedback. As for the the others commenters I've heard mud flaps decrease mpg due to having more drag. I was only curious and asking a legitimate question. Thanks though.
12-28-2016, 04:23 AM | #12 |
Drives: 2014 GT86
They may decrease slightly at highway speeds. I don't think you should care though, after all, you install them to protect paint, so probably that is of more importance then slight MPG drop, right? Also IIRC USDM fr-s-es might lack plastic underside body panels. If you care about MPG that much, you may consider retrofitting those to reduce drag.
12-28-2016, 08:06 AM | #13 |
The Gunshine State
Hopefully my shark fin antenna drastically improves my MPGs.
Current DD: M235i |
12-28-2016, 08:26 AM | #14 |
Drives: 2014 GT86
All of those parts, antenna, sidemirrors, underpanels change drag by little. "Drastically"? If only by placebo feel. Though if they all are changed, cumulative difference probably will be noticeable enough (guesstimate combo of all those to be worth some .. 2-3mpg? And then again putting on stickier tires or big GT wing will make those efforts naught again ).
Similar Threads | ||||
OEM mud guards | fitcious | Scion FR-S / Toyota 86 GT86 General Forum | 37 | 08-04-2015 09:54 PM |
OEM Mud Guards | Annahra | Exterior Parts (Aero, Lighting, Etc.) | 2 | 03-04-2015 06:42 PM |
WTB: OEM Mud Guards | akiranakayama | Exterior Parts (Aero, Lighting, Etc.) | 0 | 03-25-2014 01:09 AM |
FS: OEM Mud Guards | White0utFrs | Exterior Parts (Aero, Lighting, Etc.) | 7 | 03-21-2014 01:21 AM |
Anyone getting mud guards? | zoomzoomers | BRZ First-Gen (2012+) -- General Topics | 13 | 06-15-2012 08:40 AM |
