Old 05-23-2015, 10:50 PM   #1709
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by aschnell View Post
They have a link issue on their website. I had the same issue once. Made me crazy. If you go through links in certain sections of their site it only brings you to the 1.59 maps. I think If you go through the menu up top and dig down to our car it brings you to the correct 2.x stuff.
I've also found an older version of the site as well where there are 1.3 maps bottom line the site could use a little organization
Old 05-24-2015, 01:30 AM   #1710
FRSBRZGT86FAN
Just ordered it from amazon!:[ame="http://www.amazon.com/gp/product/B00NO2IJMM/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1"]Amazon.com : OpenFlash Tablet : Car Electronics[/ame]
Hopefully everything goes smoothly and the high praise I've heard applies to my vehicle
Old 05-24-2015, 03:47 PM   #1711
Aussie
Drives: 2013 Scion FR-S 6MT
OFT with a new ECU
I am running OFT+OFH with the Stage 2 UEL 91 Octane tune and have been delighted with this combination.
Unfortunately last week the CEL came on and upon investigation it was the P0016 code (Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor A)).
I bought it to the dealer I bought it from who refused to look at the problem as I had modified the car. Needless to say they are no longer on my Christmas card list! Another dealer has diagnosed the problem to a faulty ECU and will replace it.
My question: Presumably the new ECU will come with the standard tune. Can I reinstall the OFT tune by simply erasing the OFT and reading the standard tune from the new ECU. Logically this would make sense but I thought I should ask the community first.
Thanks
Aussie is offline   Reply With Quote
Old 05-24-2015, 04:21 PM   #1712
D_Thissen
D_Thissen's Avatar
@Aussie I think you would have to flash your original ECU back to stock and then erase the OFT. Then once you have the new ECU installed you would reflash it.
Old 05-24-2015, 04:27 PM   #1713
Aussie
Bother that is impossible as the car is at the dealership and I will not have access to it before the new ECU is installed. Perhaps I should ask the good folks at OpenFlashTablet.com?
Old 05-24-2015, 04:31 PM   #1714
D_Thissen
D_Thissen's Avatar
Shiv might be able to erase the data on it for you. I'm sure if you sent them an email they would know what do to.
Old 05-24-2015, 04:31 PM   #1715
Aussie
Thanks for the good advice.
Old 05-24-2015, 04:33 PM   #1716
DFWFRS
Product Developer
Drives: 2015 FRS Asphalt 6MT
If you don't unmarry it from your ECU, you will not be able to use it on the new one. You would have a paper weight useless OFT.
DFWFRS is offline   Reply With Quote
Old 05-24-2015, 05:29 PM   #1717
D_Thissen
D_Thissen's Avatar
Thanks
@steve99
The Following User Says Thank You to D_Thissen For This Useful Post:
Aussie (05-24-2015)
Old 05-24-2015, 06:04 PM   #1718
steve99
Yes as stated you need to flash back you stock tune to the original ecu to unmarry the oft from that ecu..
maybe ask the dealer if you can get some " personal items" out of the car and while you doing that flash ecu to stock.
if not possible talk to the openflash guys, maybe send them service reciept showing ecu change, they may be able to sort it for you but it kay require you to mail oft back to them.
its always best to flash stock tune before service for this reason.
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Aussie (05-24-2015), Fareast auto part (06-25-2015)
Old 05-24-2015, 10:43 PM   #1719
jaorocks1
jaorocks1's Avatar
Drives: 92 Prelude
Noob question but when switching from E85 TO 91 should I run the first tank at low rpms since the e85 is diluting the 91? Or is that not how it works... Also are the gains immediate? Or do they adjust over time thanks guys
jaorocks1 is offline   Reply With Quote
Old 05-24-2015, 10:56 PM   #1720
churchx
churchx's Avatar
Drives: 2014 GT86
Think of it this way: E85 is somewhat 'better' fuel (economy drop and it's agressiveness to old types of fuel lines aside, but in terms of detonation number and cooling of engine). If you switch to less aggressive tune with more conservative timings there will be nothing wrong while there still be some E85 leftovers in tank slightly enhancing resulting mix of fuel. You just won't be able to exploit that slight enhancement with your less aggressive tune for 91, that's it.
Old 05-25-2015, 08:21 PM   #1721
steve99
you need to re-tune for E85 to petrol switcheover unless you have flex fuel kit
after re-flash take it easy for a few miles to let fuel trims adjust.
see here
http://www.ft86club.com/forums/showthread.php?t=67310
then read most of links below :-)
Old 05-26-2015, 09:31 PM   #1722
Aussie
Update: The dealer replaced my ECU and after first checking the VIN and type of ECU I was able to flash my Stage 2 UEL 91 Octane tune without any issues. As steve99 suggested via PM it appears that OFT is married to a particular VIN number and as long as the dealer sets the VIN appropriately then you should be golden.
In addition to steve99 I would like to also call out positive response I got from the OpenFlash guys who were willing to help me out if things didn't work out.
Thank you all.
The Following 3 Users Say Thank You to Aussie For This Useful Post:
D_Thissen (05-26-2015), flippy (06-17-2015), steve99 (05-26-2015)
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 03:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 03:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 08:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 11:53 AM
