BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ |
03-15-2022, 12:52 AM | #113 | |
Drives: '22 BRZ
The Following 3 Users Say Thank You to eyeballs For This Useful Post: |
04-06-2022, 05:19 PM | #114 |
Drives: '22 BRZ
My saga continues. I've acquired a set of T6 sensors from Tire Rack and some 225 Indy 500s. Hard to believe spring is already here. My tires will ship sometime in late April, supposedly. Going to have Discount Tire program the sensors. I will report back!
The Following User Says Thank You to Panda Grahams For This Useful Post: | AK2112 (04-06-2022) |
04-07-2022, 12:11 AM | #115 |
Drives: '22 BRZ
I really liked the indy 500s for a daily/mild track tire when I tried them on my rx-8. Nice and quiet/comfy on the street and held up to well to track use.
The Following User Says Thank You to eyeballs For This Useful Post: | Panda Grahams (04-07-2022) |
04-21-2022, 08:13 PM | #116 |
Drives: '22 BRZ
Finally, success! For the first time, ever, my car does not display a TPMS warning - huzzah! T6 Tire Rack sensors and the 2021 Camry setting did the trick. Discount Tire was unwilling to program using the Camry settings (got a grumpy associate that day). No matter, I was able to perform the TPMS program at home.
The Following 3 Users Say Thank You to Panda Grahams For This Useful Post: |
04-22-2022, 01:04 AM | #117 | |
Drives: 2023 BRZ Limited
And just as a reminder... Which tool did you use again? I would want to buy the same one, so I don't have to reinvent the wheel. |
04-22-2022, 11:17 AM | #118 |
Drives: '22 BRZ
08-05-2022, 11:59 AM | #119 |
Drives: 2022 BRZ
The TS501 is $199 on Amazon, but they do offer periodic discounts. I got mine for $174 with a $25 instant coupon.
Also, Autel hasn't released an update for our cars as of August 1 so the 2021 Camry is still the workaround. |
08-08-2022, 02:27 PM | #120 |
Drives: 2022 GR86
Does anyone know where I can get rubber seals (or a "rebuild kit") for the T6 sensors?
I was transferring one of the sensors to a new set of wheels, and my tire shop told me that one of the seals doesn't look very good (cracked?) and they suggested replacing it next time I do a tire change on that wheel.
Follow the build thread for my GR86!
08-08-2022, 03:31 PM | #121 |
Drives: '22 BRZ
I've always just let the tire shop deal with it, but a generic metal valve stem TPMS rebuild kit should be fine.
08-13-2022, 03:35 PM | #122 | |
Drives: 2022 BRZ
https://www.tirerack.com/tpms/detail...odClar=Limited |
The Following User Says Thank You to azndavepgh For This Useful Post: | timurrrr (08-13-2022) |
08-13-2022, 08:06 PM | #123 | |
Drives: 2022 GR86
Also, now that I think about it, Toyota rebuild kits for cars that use the same sensors should work as well? On parts.toyota.com, 04423-0E010 "fits" latest Camrys, Corollas and Avalons, but GR86 isn't listed.
08-17-2022, 09:16 AM | #124 |
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
Wow... 9 pages of issues to try and fix something which is normally so simple. This is the first car I've owned with TPMS which requires a programming step with a specialized tool and/or dealer intervention. My previous VW and BMW simply took a couple button presses to synch things up.
Anyway... The whole reason I landed on this thread. Next season I'm going to run a set of dedicated wheels/tires for autocross. My initial thought is to skip TPMS sensors on that set totally for the sake of simplicity and cost. Based on what I've read here, the worst that happens is you get a small warning light, correct? No other issues with the vehicle, i.e. won't allow track mode? |
08-17-2022, 09:39 AM | #125 | |
Drives: 22 BRZ limited
The Following User Says Thank You to dragoontwo For This Useful Post: | Desertnate (08-17-2022) |
08-17-2022, 11:45 AM | #126 | |
Drives: what
modern VWs are nice in this regard because they just use the ABS sensor to determine if you have a low pressure tire. the sensors are fiddly and unnecessary imo. |
Similar Threads | ||||
Intermittent Wipers backwards | Runner10 | Issues | Warranty | Recalls / TSB | 32 | 04-07-2023 12:23 AM |
Schrader 33500 TPMS EZ Sensors compatible with Rays wheels? | Infinity | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 04-07-2020 05:08 PM |
Carsguide: the refresh is a step backwards | Sport-Tech | Scion FR-S / Toyota 86 GT86 General Forum | 30 | 03-21-2017 04:31 PM |
Someone's backwards response to me on Reddit | Linseal | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 07-29-2013 01:35 PM |
How to make the dealership bend over backwards? | Kiteless | Scion FR-S / Toyota 86 GT86 General Forum | 48 | 10-30-2011 05:05 PM |
